1949 jd B wiring diagram
gmc ronnie
05-10-2006 16:59:02
i need a wireing diagram for a 1949 jd B , 6 volt , delco distributor , key swicht ect , ect .thanks ron
Paul from MN
05-11-2006 10:47:16
 Re: 1949 jd B wiring diagram in reply to gmc ronnie, 05-10-2006 16:59:02
third party image
Here you go
F-I-T
05-11-2006 11:12:07
 Re: 1949 jd B wiring diagram in reply to Paul from MN, 05-11-2006 10:47:16
third party image
Paul:
I think you meant to post the picture in your message as well. To do that, you have to right click and copy the "Properties" information into the Image url below.
BTW, got kind of a chuckle out of the "spaghetti behind the dash" comment. I mean on a an old "B", there's two wires from the generator to the dash, another one from the starter hot to the battery side of the ammeter, and two from the service side of the ammeter to the light switch and the ignition switch if equipped with a distributor. Other than the runs to the lights, 4 wires is tough to call spaghetti.
Frank
Pete/ME
05-12-2006 03:10:36
 Re: 1949 jd B wiring diagram in reply to F-I-T, 05-11-2006 11:12:07
Yeah, but Frank for me electricity is a strange and mysterious science, I need a diagram to replace the batteries in my flashlight. My B had been added to and subtracted from over the years since 1948 and it took me a while to figure out what was what, and what wasn't.
Paul from MN
05-11-2006 13:14:57
Thanks Frank. You're right that is exactly what I was trying to do. If you had not posted your instructions, that was probably the last time I'd try. I learned something.
Pete/ME
05-11-2006 02:56:02
Even when you get the diagram (by the way, there's one in the SM), you'll find it difficult to figure out just where the wires get placed. John T had some good suggestions, check the archives. I'm right in the middle of putting together my '48 B and am not sure exactly where to snake the gen. wires, not to mention the dash spagetti. I'm going to find a B somewhere to get some idea. By the way, "gmc", you got an old truck?
CLW
05-10-2006 20:29:38
How are we to get it to you. (no email) You need to post your email as some of us, me for sure don't know how to send attachments through the board. If you rather not post it you can email me and I will try to send you a copy.
