7410 mfwd hub
hot bearings
05-09-2006 20:31:16
just installed mfwd hub on 7410 did it by the book it said to torque special nut to 130ft pds seemed pretty tight, now it get warmer than the other side after drove it 3 miles in road gear, is the the book wrong or maybe nobody uses the book and just tighten brgs by feel??thanks
G/MAN
05-10-2006 07:51:33
 Re: 7410 mfwd hub in reply to hot bearings, 05-09-2006 20:31:16
The books is more than likely correct. 8000 MFWD hub nuts get torqued to 150-160 ft.lbs. The reason it's getting warmer is that it IS tighter than the other side, because the other side probably hasn't been apart and some of the bearing preload has gone away over time as the bearings have worn. Run it.
cannonball
05-10-2006 04:20:15
are you sure that was 130 ftlbs or 130 inchlbs sounds awful tight for bearing...may god bless this usa
luckyman7m
05-14-2006 08:07:57
 Re: 7410 mfwd hub in reply to cannonball, 05-10-2006 04:20:15
That is the correct torque for the nut. I have rebuild many of them and no problems to speak of. Did you break in the new seals correctly, by not going any faster than 5 mph for 5- 10 mins. It usually helps to get everything seated good that way. You did refill the hub with oil? correct. I wouldnt worry about it.It probably is that the preload is gone away some on the other side.
