6 or 12 volt
gmc ronnie
05-09-2006 13:09:02
i have a 49 jd B , it has a delco distributor , and a 6 volt generator , should i stay with the 6 volt or go with the 12 ? i only have the disrtibutor and generator right now , if some one could say either 6 or 12 volt can you tell me the rest of the stuff i need and the way it can be wired thankss RON
Paul from MN
05-10-2006 07:02:37
 Re: 6 or 12 volt in reply to gmc ronnie , 05-09-2006 13:09:02
Personally, I would stay 6 volt. But I suppose it really depends on what you want out of it. 6v is original and if everything is in good order that B will start no problem with 6v.
What do you need if you stay 6v?
Cables - your car probably has 4 gauge cables, a 6v tractor should have 00 gauge. Generator
Voltage regulator
Starter
6v Coil
If you decide to go 12v you can get by with 4 gauge cables. You would need a 12v regulator and either a 12v coil or you can keep the 6v coil and add a balast resistor. You should be able to use the same generator and starter. If you go 12v you'll also need to replace your light bulbs with 12v bulbs.
gmc ronnie
05-10-2006 13:57:33
 Re: 6 or 12 volt in reply to Paul from MN, 05-10-2006 07:02:37
i have the distributor, the 00 gauge battery cable, the 6 volt generator, i guess i need a 6 volt coil, do i need a key swith , .
Paul from MN
05-11-2006 13:09:55
 Re: 6 or 12 volt in reply to gmc ronnie , 05-10-2006 13:57:33
you can use the same switch.
johns48b
05-10-2006 04:15:31
i personally don't like to see tractors converted to 12 volts. jd pub sm2029 has a wiring diagram in it for a b. if everything is right your b should crank good with just 6 volts. its yours you can do what you want, but it might lose some value if you ever decide to sell it if you convert it to 12 volts
Clear as mud
05-09-2006 21:19:23
Your write up doesn't exactly say what you are trying to do, so it's not easy to give you any kind of answer. Be more specific.
gmc ronnie
05-10-2006 02:02:02
 Re: 6 or 12 volt in reply to Clear as mud, 05-09-2006 21:19:23
i'm trying to rewire the tractor for the charging/fireing sytem,
