Break Hub Loose on JD A
Soldner
05-09-2006 11:08:55
Hello Everyone, I'm just wondering if you guys would give a young guy some ideas on how to break the rear hubs loose on a 49 JD A. It has the pressed steel wheels, and they are pretty stuck. Thanks for all the great advice!
Frank in WV
05-11-2006 07:49:31
 Re: Break Hub Loose on JD A in reply to Soldner, 05-09-2006 11:08:55
I had to resort to the heat and beat method with a puller adapted onto the hub. Take the wheel off if possible to make it easier to beat. Takes a lot of heat. I used penatrant before but wouldn't work. Heat beat and pull with a big gear puller was my method. then clena the splines and either use wax paper or a little never seize when you put them back on.
Earl-Il
05-10-2006 13:43:09
Loosen hub and drive tractor around as been suggested in previous quote. I have good luck of jabbing the brake .CAUTION ....BE CAREFUL ONE WHEEL AT A TIME . Leave the bolts in. Just back off 1/4-1/2 in. Earl
Soldner
05-10-2006 07:56:47
Thanks, I'll try both penetrating, and heat..
amo
05-10-2006 05:54:12
loosen bolts after soaking and drive around some if operatable. good luck.
Deerly Parted
05-09-2006 19:28:08
I've done many. Heat and beat is the fastest but if heat isn't available soak with any type penetrating oils. Last resort I've used on some is to soak with water and wrap rags or towels around the hub for extended periods. It seems water gets into places the other lubricants can't. A big sledge and some cussing is last resort. Good luck.
