720 clutch
pwd
05-09-2006 07:09:51
i can't adjust the clutch so it snaps or locks in. am i doing something wrong or is something worn out or broken? the clutch plates still have some life in them.
2cylinderlp
05-09-2006 09:42:23
 Re: 720 clutch in reply to pwd , 05-09-2006 07:09:51
Has is ever worked properly for you? Do you have the three adjustment nuts turned down all the way to the end of their adjustment and it still won't snap in? If so, it still could be lots of things. I had one like that recently and it turned out to be a worn out and cracked clutch collar which was flexing when it shouldn't. You should do a complete disassembly of the clutch pulley and associated parts. Clean everything and inspect for worn parts. Clean and repack the roller bearing too. It could run into a few dollars depending on what is in need of replacing. You will need a puller for the clutch drive disk. Also a long punch for the bearing and other common mechanics tools to do the job.
Soldier Tom
05-11-2006 17:24:44
 Re: 720 clutch in reply to 2cylinderlp, 05-09-2006 09:42:23
It cost us over 700 to totally rebuild the clutch on our 720 d'sel. Now that was all new stuff: sleeve, dogs, toggles, bolts, all the discs except the drive disc. I also bored out and sleeved the clutch lever, and rod where they were all wallered out and new bearing in the collar. We took the flywheel off and put new felt washers there to fix the endplay on the crank. It was a lot of stuff, but the clutch is brand new and yea, it snaps in and out just like it should. They are good when they are right, but it takes it a while to get them right.
Good luck!
~Walk in peace~
pwd
05-09-2006 12:53:48
just bought the tractor so it's never worked right for me. i just took the disks out. i'll take apart further. thanks
