2 remotes for a 720
pwd
05-09-2006 06:36:54
i have one remote on a 720 diesel. i need to add one. any way to do that? thanks
Doug in IL
05-09-2006 06:45:50
 Re: 2 remotes for a 720 in reply to pwd, 05-09-2006 06:36:54
You need the dual remote valve box. I have one on my 720. They are available from some used parts vendors. Expect to pay around $700 for the complete setup.
pwd
05-09-2006 07:06:24
 Re: 2 remotes for a 720 in reply to Doug in IL, 05-09-2006 06:45:50
i need a cheaper way than that. any way to do it for less?
Hilltopper
05-09-2006 18:33:06
 Re: 2 remotes for a 720 in reply to pwd, 05-09-2006 07:06:24
I use a diverter valve on mine in order to pull a round baler. It will work if you only need to use one outlet at a time. I mounted the diverter to the left of the seat. It has a knob to pull or push to change the flow. I put 1/2 npt tee in the hose behind the bottom remote outlet and run a hose up to the diverter.The diverter then has 2 outlets to which I plumb 2 quick couplers. You then need to put a 1/2 npt tee in the upper outlet hose a nipple and a elbow and another nipple then a quick coupler. This becomes the 2nd return. It works very well You set the diverter then use the remote cylinder lever as usual. Probably cost less than $200.
