Duane, Glen or ? on D timing
jas
05-08-2006 18:47:20
I know there has been many a post about timing but here is another. I am helping a retired guy put back together a 38 D that his dad bought new. Been Sitting for years, Stuck valves, no spark, dirty carb. You know the type. Well, we got it running tonite but it seems like it want's to run backwards. I timed it all by the book. Starting at the gov. housing wich we had off because the gasket leaked horribly. I had the mag impulse just as the flyweel hit the mark. But after it hits on #1 and then tries to hit on #2 and take off, it seems like it hits too early on #2 and than it sends the flyweel backwards quickly. Sometimes it will roll through but it seem lik 50% of the time it tries to or does go backward. I loosened the mag and turned it till the mag impulses way after the marks have done lined up. But it still acts like it is too early on #2. Eventually we pulled it about 6 feet and it took right off. Doesn't run half bad but its got to start better. Any suggestions? I think it has all the correct stuff for a 38. Mag, carb, etc.
jas
05-10-2006 09:54:05
 Re: Duane, Glen or ? on D timing in reply to jas, 05-08-2006 18:47:20
Ok see if I have this right... First make sure mag is clean and correct under cap. Then double check to see if mag impulses when marks line up on flywheel to case. This would be start timing. Is this also known as static timing? Then degree flyweel and start tractor. With timing light check to see amount of degress before tdc. Should be 35 degrees? Also if the cam was out of time, would the drive be horizontal and would it still run decent? I wo't be able to write back till next week, got to many things going on till then. I will make a new post so we don't have to search for this mess again. Let me know if this student has learned correctly from the teachers. Talk at you fine gents later.
Duane Larson
05-10-2006 10:53:52
 Re: Duane, Glen or ? on D timing in reply to jas , 05-10-2006 09:54:05
jas,
I believe you have it. Static timing is the same as starting timing. I find it useful to mark 25, 30, 35, 40 on the flywheel with chalk, being careful not to wipe it out when starting, and see which mark lines up with the mark on the case when the tractor is running. The camshaft could be out of time and the governor shaft/magneto drive slot still be horizontal, since the only timing requirement on the governor shaft is the drive cup be horizontal. If you get into checking this system, also make sure your flywheel is correctly placed on the crankshaft - but if you have little vibration when running it is likely ok.
Keep us posted.
Glen in TX
05-10-2006 10:49:25
Sounds like you are getting and yes you will want to see 35 deg. when checking with timing light.
For timing the cam you are actually timing the valves as well and would be adjusting them and tappets. If you have more problems getting it timed right later post back and we can give instructios for that or find a manual for it. The DIR225 Instructions manual gives instructions for that as well as many other service and repair tips and covers the 1931-38 D. PC658 is unstyled D parts catalog. Copies are available from JD publications.
Glen in TX
05-09-2006 22:14:12
Just a thought of something else you may want to check and I've run across it before is make sure the cam is timed correctly also. If you don't have D manual and need that procedure let me know.
jas
05-09-2006 17:52:20
Yes we have the edison cd on it. Thanks glen, for the procedure. I think I did it all pretty much like you had written. I believe that this mag only fires on the compression strokes. Yes? I thought I had it right the first time but it didn't start and that led me to believe that it doesn't fire every time. I can hear it impulse, not as loud as my 48 or my 29 D's but that may be just that it is a different mag than either of those. I know that the drive lugs were horizontal when I installed the mag. We fired it up tonite again. This time by hand. It still tried to run backwards several times but it did finally take off. Thanks to you guys for now. I will check the cap like Duane said but since the local repair shop checked it out and put points in it, I don't suspect anything but you never know.
Glen in TX
05-09-2006 22:04:01
 Re: Duane, Glen or ? on D timing in reply to jas, 05-09-2006 17:52:20
Yes, the CD fires on compression only when timed correctly. I use to run one a D for tractor pulling for that very reason. Sorry I didn't make that clear. Time to rewrite the timing instructions again? lol. Like Duane mentioned earlier usually cleaning the dist. rotor disc of carbon will help and is all that is needed with that. A very few I've seen had a cracked rotor disc causing a short or miss in them. Also like Duane explained the CD impulse is not adjustable but the weights and a trip roller on plate screwed to mag can wear and impulse springs can break a few coils off or get weak too. If you still have problems let us know. I've got a few NOS CD impulse parts yet but not many.
Duane Larson
05-09-2006 19:31:15
jas,
Sounds like progress. You are correct in that for the CD 0010 magneto, for four impulses two sparks are produced. No sparks are produced for the exhaust stroke. The pattern is click(spark from rh mag terminal), click (spark from lh terminal), click (no spark), click (no spark) - and the pattern repeats itself.
The impulse (ie, starting) timing is not adjustable on the CD, and the magneto drive cup determines when the running time spark (ie, non-impulse) is produced. Most drive cups for the CD 0010 are 35 deg cups, which means the running spark is produced 35 degrees before the starting spark - since the starting spark is at TDC the running spark is 35 deg BTDC.
Post back if you continue to have problems.
Duane Larson
05-09-2006 06:27:06
jas,
In addition to Glen's nice response about static timing for the various magnetos, I can add a few other thoughts. First, we need to know what magneto you have. The D came with the Edison Splitdorf CD spec 0010 that Glen referenced. If that is the magneto you have, you might pull the distributor cap and look inside to make sure both brushes are in place and look good, there is no black streaking on the distributor rotor (you can clean it by rubbing it with an eraser), and the thin metal "safety gap" washer is in place behind the rotor. If any of these have an apparent problem the relative timing of the spark can be different from the standard 180 degrees.
It might also be useful to find the present running timing after you pull it to get it going. That can be done with a timing light and a battery to power the timing light. You can find my method by typing in LARSON MAGNETO TIMING PROCEDURE LIGHT in the archive search box. Use of a timing light will show the relative position of the two sparks and help get the running and starting timings correct.
But let us know what magneto you have.
Glen in TX
05-08-2006 21:50:35
Jas, You said it started okay pulling it. Makes me think the impulse spring is broke or other impulse parts worn badly. Is the impulse snapping when you rolled it over? Which mag do you have? If it's the Wico C or XH you can try switching the wires around as those fire on compression and exhaust. Also the later Wico XH puller mags we build just fire on compression though and have a special cap like a 4 cylinder with 2 grounded out and can't switch wires on those. The impulse stop ring has to be set right also on a Wico and worn parts can affect it some too so let us know what type mag and where that is set at and drive cup number if there is one. If you have the Edison Spitdorf CD mag or other Splitdorf mag those have a gear reduction rotor and will have to timed exactly right to compression on LH cylinder and can't be switching wires around. Impluse springs break on those too and parts wear out. Make sure when you had engine set to time and install mag that the governor drive slots were horizontal. If off some you will need to reset a tooth or two by lifting the governor again and aligning gears to get the drive slots horizontal with LH cylinder on TDC. Standard timing instructions I send out.
Magneto Timing for JD D and other Waterloo JD tractors with flange mount magneto :
1. Remove spark plugs from the engine and turn flywheel forward in direction it runs until you feel some pressure of air coming out the LH # 1 cylinder (flywheel side) spark plug hole as it is coming up on compression stroke. (If you don�t feel or hear air coming out it is on exhaust stroke and keep rotating till it comes up on compression stroke.)
2. Turn slowly as it comes up on TDC (top dead center) of compression stroke and watch as the mark on flywheel �L.H. Impulse� comes up in line exactly at the 3 o�clock position with the mark on transmission cover or housing. Stop when marks are in line with each other. (Note): The later model A,B,AR, & 50 tractors with flywheel cover will have a mark or notch on lower end of cover hole to align with flywheel punch mark instead of marks mentioned above.
3. In this position the slot in coupling on governor shaft should be horizontal. If it is not horizontal when LH cylinder is at TDC and governor had been removed previously this will have to be aligned and corrected first.
4. If slot is now in horizontal position you are ready to install the magneto.
5. Make sure points are set at .015� for Edison Splitdorf and Wico magnetos.
6. Edison Splitdorf magnetos when mounted use the forward terminal on distributor cap for # 1 LH cylinder. Can mark with chalk if necessary. 7. Wico magnetos will use the top terminal in distributor cap for #1 LH cylinder. Can mark with chalk if necessary.
8. Connect wires and spark plugs in distributor holes of magneto and have the magneto frame and plugs grounded with plugs out of engine.
9. While turning the magneto slowly in a left hand direction (CCW) facing the drive end watch for a spark from the #1 LH cylinder plug that would be connected to forward terminal on Edison magneto or top terminal on Wico magneto.
10. When you get a spark on the LH terminal stop and the drive lugs of magneto should be in a horizontal position. 11. Being careful to not disturb that position install the magneto on tractor using one or more flange gaskets and install bolts only finger tight.
12. If you notice a binding and magneto flange does not pull up tight to flange when tightening bolts finger tight you may need to shim out with more gaskets being careful drive lugs align in slots also.
13. Then rotate the top of magneto toward the front of tractor as far as possible.
14. Then slowly rotate the flywheel forward one complete turn slowly coming up on the �LH Impulse� mark on flywheel to align exactly again with cover mark at 3 o�clock position. Then stop in this position. 15. If you went past the mark you can rotate the flywheel back and come up on mark again but if you rotated too far forward and tripped the impulse in magneto you will have to remove magneto and start over. 16. Now carefully and lightly tap the top of magneto slowly toward the rear of tractor a little at a time until you hear the impulse trip. Stop.
17. Tighten the bolts holding magneto to governor case taking care to not over tighten. If flange does not pull up flush do NOT over tighten to pull it up more.
18. Use another gasket to shim magneto farther out instead. Failure to heed this advice shimming the magneto properly with gaskets can result in breaking the magneto housing. 19. Problems getting magneto to align by having to use several gaskets may also indicate previous improper assembly of governor or worn governor parts.
20. Gap spark plugs at .030� before installing in cylinders. 21. Install spark plug wires so wire in upper terminal of Wico magnetos or forward terminal of Edison Splitdorf magnetos is connected to the LH cylinder spark plug. Lower or rear wire connects to RH cylinder.
22. If magneto is equipped with a threaded stop terminal you may add a shut off grounding switch to this terminal.
23. NEVER connect battery voltage to a magneto or to stop terminal !
24. A magneto produces it�s own power and does not need power from a battery.
gold-leaf-deere
05-08-2006 19:44:16
I had a simular trouble with a Hand crank A, The trouble was that the previous owner had the mag drive installed 180 degrees wrong, it was timed correct, but he had the wires crossed, with the wires crossed, the engine could be timed and the left cylinder would fire real strong but the right side would fire way early and the engine would attempt to run backwards. I tractor pulled the tractor all one summer and was competive, to start the tractor, we rolled it off of the gooseneck and went to the track. one tim,e at a Kentucky pull, another puller told me that the wires were crossed and explained what was going on, hope this might be a simple fix for your D
