wheel wobbling 1950 AR
Bigolebear
05-08-2006 17:36:30
I have a 1950 AR which has wheel wobble from third gear on up. The I.T. manual only covers reg. A's that have shimms to adjust the steering gear. The parts book for AR's don't show shimms, but does show a adjusting nut. The other steering parts seem tight but the steering wheel has lots of play so I think it is in the steering gear box.
Does any one know how to adjust and set the steering gears.
Bigolebear
05-09-2006 07:47:51
 Re: wheel wobbling 1950 AR in reply to Bigolebear, 05-08-2006 17:36:30
Thanks for the info. I will check into it further and see if I can get the shaking tamed.
Glen in TX
05-08-2006 22:04:45
There is a set screw with lock nut on steering box that gives you some adjustment. Best way is to jack up the front end while adjusting it. If you get binding after changing the set screw some you may need to reshim the gears in box. There are thick and thin gaskets used on the gear box to shim the worm to gear. If it still binds after that or too loose look for wear in the shafts in gear box and gear box bore under gear and lower gear box shaft bushing in trans case. Simular setup to the D steering gear box and on those I've had some worn so much inside the gear case the upper end had to be rebushed and shaft built up and a shim washer used under gear in case to get aligned with worm properly again. There are shims on the spindles at the king pins also and you can make new king pins and axle pivot pins from regular shafting and rebush axle also if needed.
Leroy
05-09-2006 06:10:12
 Re: wheel wobbling 1950 AR in reply to Glen in TX, 05-08-2006 22:04:45
Yes you can adjust the gears that way but the middle area of the sector wears and if you adjust so that area is tight then you have it too tight that you can't turn to end of travel as the outer ends of the sector do not get worn as they are not in use as much. That is same problem as the row crop JD and Farmall and all others with that type of stearing gear have but with the wide front you also have all the other spots that will wear as well but on ours there was no wear on those other parts, the arm on the bottom of the vertical shaft had come loose before we had the tractor and it was welded to the shaft and when it broke the machine shop could not get it apart to even make a new shaft and that arm was no longer avaible and that was 25+ year ago. We bought the tractor at auction and in trying it out there was absoulatly no play slop in the wheel but as soon as you hit the road you found it out. Could not haul grain to elevator with it till after we had it changed. Too hard to keep on road. Also had same problem with 5000 Ford but other Fords (4000) no problems.
Glen in TX
05-09-2006 12:06:02
 Re: wheel wobbling 1950 AR in reply to Leroy, 05-09-2006 06:10:12
Leroy I can see your point about a section of the gear and worm wearing out too but I usually had more problems with these simular setups on the Ds having bad lower shaft wear. Darned thieves stealing diesel out at 3:30 am got me on a rough, ragged and mad way today. Chased the dern *&^%$ over into NM this a.m. and they got away from us in a truck. We got to chase them or deputy could never even begin to find them here in boonies but still lost them. Anyone that wants to go 90+ with no lights in 18 wheeler can have the fuel I guess?
Glen in TX
05-09-2006 07:36:07
 AR - AO steering in reply to Leroy, 05-09-2006 06:10:12
AR-AO steering
third party image
third party image
Glen in TX
05-09-2006 06:59:22
I'm sorry Leroy but he said a "AR". The AR steering gear doesn't have a sector eccentric bushing in it... It's a wheatland type with completely different steering box than a row crop. Inside the gear box is a worm gear and mating bevel gear only and no eccentric adjusting sector. It is adjusted with the set screw or by taking the gear box apart and varying the number of thick and thin shim gaskets between box and worm gear box section just like for the Model D steering gear boxes.
Leroy
05-09-2006 18:20:44
 Re: wheel wobbling 1950 AR in reply to Glen in TX, 05-09-2006 06:59:22
What you are refering to as a mating bevel gear is what I called a sector gear and that in our 50 AR was not wore but still shook. Had them ware on both A & B and on a Farmall H the worm had to be replaced as well. on these others you tighten supposedly by turning the bearing but I found out that if you do that you will have other problems
Glen in TX
05-09-2006 21:52:23
 Re: wheel wobbling 1950 AR in reply to Leroy, 05-09-2006 18:20:44
Ok, after rereading I had realized that was what you were calling it. Yeah, a worn gear or sector just causes more problems and those have to be replaced sometimes too if you can find better ones.
Leroy
05-10-2006 05:43:22
 Re: wheel wobbling 1950 AR in reply to Glen in TX, 05-09-2006 21:52:23
We are getting on the same page now as to understanding each other, In our area D's were verry rare and AR's were also an uncommon tractor. If I remember correctly that gear on the AR can be rotated to a different place on the shaft to get to an unworn spot while some like in the A row crop (common) were just a half gear and could not be turned and we ended up replacing the bearing that you were supposed to be able to turn to tighten because turning it caused the steering to bind
Leroy
05-08-2006 19:28:26
That is a commen problem even with everything tight, found no way to get rid of it on the 50 that we had. Ours had the shaft that goes up & down thru case break and we could not find one so we converted to hydrostatic steering with a cylinder on the front axle and after that instead of taking 2 hands to turn the wheel one finger would do it and it got rid of the shimmie. even tho everything is good I think that it is something to do with camber/castor and flex in the steering shafts.
