210 drive belt
sdale9585
05-08-2006 13:24:13
I have a '78 210 and every season I go through the same problem. The secondary drive belt refuses to stay on. Constantly jumping off. So far the only fix I have found is replacing the belts 2-3 times a season, but that is getting exspenive. I've replace all the pulleys but the idler pulley, which seems fine. Any help or suggestions would be greatly appreciated.
buckeye al
05-08-2006 14:22:17
 Re: 210 drive belt in reply to sdale9585, 05-08-2006 13:24:13
Are you using Deere belts? My experiences have been that a Deere belt (either primary or secondary) for these mowers will out last a hardware or 'other' parts store belt at least two to one!
To me, it's not close to worth it & I use Deere belts. That said.....
Usually chronic secondary belt fly offs are related to the belt tensioner idler arm bushing wear OR the deck is rusting out below the idler arm bushing. In both cases, the idler arm pulley is out of position with respect to the drive pulley sheave and how the belt feeds out of it.
If the bolt through the idler pulley is not parallel to the spindles, then the belt will walk to one edge or the other of the idler. A belt running in contact with the idler's flanges will wear out real fast no matter what brand! It will either wear out or walk right off the pulley, probably both.
Suggest you service the tensioner arm's bushing/bore and therefore the idler's "attitude" with respect to the belt and how it feeds out of the drive pulley sheave. Sometimes a bit of bending of the idler arm is in order to get the belt to track in the center of the idler pulley even after renewing parts. The way I look at it, if the belt contacts the flange of the idler pulley then adjustment is in order!
Good luck.
