JD 420 Hard To Start When Hot
Jay Emerson
05-08-2006 12:53:30
I have a John Deer 420 that I use to keep my property mowed. I had it overhauled six year ago. It starts fine until I run it for 30 minutes or so then becomes very hard to get it to turn over. I can let it set for 30 minutes and it starts ok, but when it's hot it's very difficut. Thanks for any suggestions.
JE
Henry M
05-08-2006 18:38:55
 Re: JD 420 Hard To Start When Hot in reply to Jay Emerson, 05-08-2006 12:53:30
Jay
If i read it right the problem is getting the motor to roll over. If so, and it is too advancec on time, I think you might get an indication of this if it rolls up on compression ok and then stops right at the top and then maybe rolls again until the next piston is brought up to fire and it fires too soon and basically pressures the piston to stop before it gets a chance to roll over the top.
Anyhow checking the timing is a freebie and a good place to start.
billde
05-08-2006 18:07:31
If what you are saying is that the engine seems harder to turn over when warm than when cool, it's a starter problem. The engine will require more power to turn it over warm, sounds like the starter is dragging a little under the extra load. Check all your cables and connections, make sure the battery is fully charged. If that doesn't solve the problem, have the starter and battery checked out.
bill from western ny
05-08-2006 14:34:51
if the tractor is not cranking over well when its hot,but will crank over if allowed to cool down for awhile could it be a problem with the starter itself? just me thinking out loud.
johns48b
05-08-2006 13:32:38
i'm not familiar with a 420 but if it has a coil its bad. it will actually quit running after a while when it gets hot, but will crank and run good when its cool.
420TEE
05-08-2006 13:31:38
Jay, I had the same problem and when I posted the same question the consensus of opinions was the timing was off. I have not had a chance to check it yet but you may want to check yours.
Jon Dear
05-08-2006 13:09:38
Does it have power steering? If it does, try turning the steering wheel back and forth and back and forth quickly while attempting to crank it when warm. Does that make a difference? If so, I have more info for you.
buickanddeere
05-08-2006 13:30:57
 Re: JD 420 Hard To Start When Hot in reply to Jon Dear, 05-08-2006 13:09:38
Rock the steering works with a closed center system. An open system is operating at minimum pressure when no loads are applied. Odds are either a condensor or coil are failing with heat. Or the carb/fuel lines are either vapour locking. Or suppling too rich a mixture from heat vaporizing more gasoline into vapour than normal.
