LA /LUC mag timing
Tech 7
05-08-2006 06:32:12
can anyone supply me with info on installing the mag on this unit? I can get close but can't get right on the money. Engine was seized when it was torn down so couldn't line things up at that time. No I don't have a manual.(shame on me)Thanks, Bob
Tech 7
05-08-2006 08:51:29
 Re: LA /LUC mag timing in reply to Tech 7, 05-08-2006 06:32:12
Thanks so much Glen....I am restoring this engine with 4-H club and the budget is tight so I scrimped on purchasing a manual....I would be subject to 20 lashes with a trouble light cord from Mr.Thinker for this! Thanks again...Bob
Glen in TX
05-08-2006 12:24:56
 Re: LA /LUC mag timing in reply to Tech 7, 05-08-2006 08:51:29
No prob but just a tip, remember you can search archives here also and many times find a answer faster than waiting as sometimes some of us here might be in a Mr. Thinker cantankerous mood too. lol.
Glen in TX
05-08-2006 07:32:20
Magneto Timing for John Deere L & LA tractors :
1. Loosen the timing cover to see inside timing hole.
2. Remove the mag dist. cap.
3. Turn engine clockwise slowly until you hear the impulse trip. Stop.
4. Then turn slightly counter clockwise until you see the spark mark on flywheel in timing hole and it lines up with mark on center of timing hole.
5. At this place the points should just be beginning to open.
6. If not beginning to open loosen nuts on mag and rotate mag inward or outward until points just begin to open and then tighten nuts on mag. If that doesn't work to time with mag removed: 1. With timing hole open turn engine clockwise until spark mark is on the center of the timing hole.
2. Remove mag dist. cap.
3. Turn mag gear counter clockwise until dist. rotor is in 10 o'clock spot and then back clockwise until points just begin to open and dist. rotor is in 8:30 o'clock spot. 4. Hold mag in this position while installing on tractor and it may be necessary to turn some to align the gears and then tighten nuts. 5. If timed properly and when crankshaft is turned clockwise until the impulse trips the D.C. mark on flywheel should be at the lower edge of the timing hole when impulse occurs. Instructions - operators manuals and parts catalogs are available from JD Publications at 1-800-522-7448 or through your dealer or by visiting the JD Tech Publications site. http://techpubs.deere.com
DIR206 Instructions for JD L tractor
DIR207 Instructions for JD LA tractor
DIR208 Instructions for JD LI tractor
PC150 Parts Catalog for L tractor
PC151 Parts Catalog for LA & LI tractors
