Do as Glen says and get the manual, but I would pretty much bet that you have a combination of flats worn on the two pins and notches worn in the centered position of both the actuating sleeve and cam faces. These combine to cause the pins to hang up in the notch. If the pins cannot slide up or down the cam face, which is how the actuator valve is moved fore and aft, then you get no power steering assist. Going from power assist to no power assist feels like the linkage is hanging up when it is really just the of the extra effort coming to light. I like to eliminate the power steering from the steering linkage by jacking the front end up so the wheels are off of the ground. With engine running, turn the wheels to the left and the right and see if it turns smoothly to each extreme, all the time, no matter how fast you move the wheel. If all is smooth, suspect that the steering assist circuit (cams and pins) is the problem. If it resists, you have a purely mechanical problem like bad worm bearings. On the cams and pins repair that is another story, but if it is not too severe, you can replace the pins with new ones, probably still buy a cam for a decent price, but the actuator sleeve is going to be pricey. The last two I did I was able to use some careful grinding and blending of the faces to achieve a nice transition up and down the cam face and actuating sleeve face and it all worked smooth as the ones I did with new parts. You can also try to increase the oil flow rate and see if this improves things, but if it does, you are probably only buying some time before an eventual overhaul. Frank
