2520 won't start with key
Tractor Tom 61
05-07-2006 17:49:20
Working on a 2520 for a relative. The key switch is working. But, when I put the key in the start position it does not get 12 volts at the solenoid. What is between the key and the solenoid? Is there a neutral switch or clutch switch that could have gone bad?
Tractor Tom 61
05-08-2006 19:12:02
 Re: 2520 won't start with key in reply to Tractor Tom 61, 05-07-2006 17:49:20
It was the neutral switch! Clean it up and it works fine! Thanks for the help Glen, Dave, and MSB!
Glen in TX
05-07-2006 22:19:01
Sounds like neutral switch or bad key switch. The switches have to shimmed properly to work right too. You can see them on a 2520 part book online at JD Parts site.
Dave Sherburne NY
05-07-2006 19:08:40
Didn't those tractors have a switch down on the j
side of the trans. under your right foot? Long time since I sold mine.
msb
05-07-2006 20:13:40
 Re: 2520 won't start with key in reply to Dave Sherburne NY, 05-07-2006 19:08:40
If its a syncrorange transmission there is a neutral switch on the right side of the transmission case.There are two switches if the tractor has a powershift transmission.The pair of yellow wires on the starter is the circuit to and from the switch-s.
