Help with G carburetor
used to be jame
05-07-2006 17:08:32
I'm trying to rebuild the carb on my '49 G. I've got Robert's video, and my carb has been rebuilt before.(I just don't know when, or by who). My question/problem is that the "drill plugs"-which are all screws in the video, are all truely "plugs" on my carburetor. Do I just drill all of them out? Is the hole going to be threaded? Is this original? I can't read the stamp after the DLTX, but there is a tag riveted up by the throttle hole. The tag says "11 86", below that "13945", below that "DLTX 108UA'"
Anyone else seen plugs like this, or can you itentify my DLTX #?
Thanks
James
Mike M
05-08-2006 10:11:18
 Re: Help with G carburetor in reply to used to be james, 05-07-2006 17:08:32
If it is not too bad I'd be tempted to just soak it in a carb. dip cleaner and not disturbe those plugs. If it has rust or heavy deposits then more than likely you got to get them out somehow.
I have a late B with one of those replacement carbs. on it. It belonged to my uncle and I remember him saying the dealer put the new one on because the old one was worn out. I guess they thought the passages or something wore ? Or maybe it never was drilled right when made new ? I'll never know for sure ,but it really does run great now.
Duane Larson
05-07-2006 18:18:49
James,
You have a replacement carburetor on your G. Marvel Schebler (bought out by Zenith) replaced all single barrel carbs with three "universal" carbs (one "B" size, one "A" size and the big nut for the "G"). The holes on your carb are not normally threaded (unless someone has worked on it). I normally drill and tap a hole in the brass plugs for a 5/40 or 6-32 screw and remove the brass plugs with a small slide hammer. I then tap the holes and replace with the usual brass plugs - www.robertscarbrepair.com has them available. You might get away with an easy-out but they don't work well for me.
11-86 is the date, 13945 is the Zenith number, and DLTX 109UA is the MS number.
used to be james
05-07-2006 18:28:32
 Re: Help with G carburetor in reply to Duane Larson, 05-07-2006 18:18:49
Thanks. Just as you were posting your reply, I found an old post of yours in the archives.
Do you think the original carburetors were bad, did someone not know how to rebuild them, or would it have had something to do with the change over from all fuel to gasoline? I just can't imagine why a new carb would be better than just rebuilding the original unless it was for the switch to straight gas.
James
Duane Larson
05-08-2006 05:54:12
 Re: Help with G carburetor in reply to used to be james, 05-07-2006 18:28:32
James,
The most common reason for replacing a carb was the old one broke. Either an ear (or two) broke off, or the neck broke. Back then a new carb was not expensive. Or, the carb could have been missing when the tractor was purchased. I doubt the old one was replaced because it "wore out".
The change to gas was done by changing the nozzle.
