730D oil capacity
mjbrown
05-07-2006 15:56:44
Changed the oil today. Checked the John Deere shop manual for crankcase capacity. It said 12 quarts. IT manual says 9 quarts. Dipstick says full at 9. What say you guys? I think I put in 3 quarts to many.
Mike M
05-08-2006 10:33:28
 Re: 730D oil capacity in reply to mjbrown, 05-07-2006 15:56:44
There is a seperate drain on the bottom of the timing cover kinda below where you turn the hyd. pump on and off. You need to drain this at every engine oil change. It will fill back up fine through the regular oil filler. The reduction gear cover on those holds gear oil and if you change the tranny you should also drain it too and it has a seperate filler hole on top. Maybe only 1 or 1 1/2 quarts ? Eventualy it and the tranny will level out as there is no real oil seal in there.
As far a total capacity ? It's been a long time and I usually use bulk oil. I also think you check it with the dipstick resting on the threads. I used to do the neighbors 720D with pony motor and I think he must of dropped off a 12 qt. case and it took all of it to do the engine,pony,and air cleaner. So I don't think the engine alone takes 12 ?
Bob
05-07-2006 16:31:37
Did you change the filter, drain the timing gear cover, and is there a drain on the reduction gear housing on a 730... I can't remember.
mjbrown
05-07-2006 16:59:12
 Re: 730D oil capacity in reply to Bob, 05-07-2006 16:31:37
Yes, no,no, don't know either. I guess I'll do some more reading.
Thanks
