JD 2510 or 3010
jdjoe_indiana
05-07-2006 12:44:55
I am looking for a nice loader tractor. I have narrowed down due to price to a JD 2510 or 3010. I would like a diesel but am not opposed to a gas. I would like any comments from experience guys who have this tractors. Does one model offer any significant mechanical advantages or durability advantages to the other? Let me know if you know of one or a loader for one in the Mid West. Thanks Joe
Brent in WI
05-08-2006 17:21:05
 Re: JD 2510 or 3010 in reply to jdjoe_indiana, 05-07-2006 12:44:55
Also don't be confused by the 10 series in the 2510 as it is not the same vintage as the 3010. As Glen said the 2510 was made after the 3010 series and they used almost all the same parts as an early 3020 except for the engine and transmision housing and few other things. It has many of the 20 series upgrades from the 10 series and can't understand why they didn't just call it a 2520 from the begining! The 2510 is a little smaller tractor HP-wise than the 3010 and might be a better all around loader tractor. I own a 3020D and 2510D and like them equally. I'd pay the extra for diesel as well but it is easy to spend someone elses money.
Glen in TX
05-08-2006 08:33:00
Any engine that the cooling system isn't serviced on is going to have cavitation problems and heard of that more so in the early 3010, 4010s but again how old are those tractors and have they been serviced well. The engine in the 2510, 2520 was completely a different design and used balancer shafts inside. Not as peppy a engine on gasoline but a very good one on diesel. These engines were used in other JD equipment also like swathers and others and not just tractors. We had a 2510 diesel with syncro range trans for 37 years and it was a joy to run and very economical on fuel. No real problems except we just ran and ran it till we wore it out. It was overhauled 3 times but that should have been twice only. First time we had just wore out the engine and had it overhauled by local mechanic. 2nd time it was just wore out again with 1000s of hours on it again but the JD merger dealership that got too big for it's britches and is gone and busted now hired poor incompetent mechanics that did a very poor job on engine and also left a rag in the trans that got sucked into the primary hydraulic pump and trans gears and bearings. So... it seized a piston in one cylinder and rag in trans ruining both pumps with dealership then not standing behind anything and going broke and JD block manager said it's up to dealer to stand behind yet they blamed the bad cylinder and sleeve on JD parts. Dealer went bankrupt and shut down by US Marshalls and lots of local customers lost a lot in the deal and got sour on buying another JD also. A 3rd overhaul was required by a competent dealership mechanic to get engine timed right again and complete engine overhaul again and trans cleaned out and pumps replaced. Then it ran like a new one again but that episode about drove me to buy one of another color but they all too have problems. A 20 series had updates for a reason and a 2510 with 2520 updates to diesel engine is an example that worked well and kept them going this long. You can update a 10 series but it's just always going to be older by the serial number. I'm still going to go look over that 2520 again but figure they are asking way too much for it.
LarrySTN
05-07-2006 20:47:24
the engines used in the 2510 and 2520 were both very proned to block cavitation (erosion) at the lower sleeve deck. The only cure is block replacement. The 3010 and 3020 engines were more durable. Of course poor maintenence will ruin most any engine, but poor cooling system service was especially hard on the 202/219 engines in the 2510/2520.
msb
05-07-2006 20:18:17
In my opinion the 2510 has a much better designed engine for several reasons which I don't have time to explain right now.
Glen in TX
05-07-2006 13:35:11
It may just depend on the price and options you find on one. The 3010 was made in 61-63 and 3020 64-72. 2510 made 66-68 and 2520 69-73. You are going to see more asked for the 2510 and 2520 than a 3010 so depends on what you want to spend. Finding one with 2 remotes is not a must as you can tee into the main hyd. line and use quick couplers there and a joy stick valve on the loader also. I've seen some places offering a HD front end conversion for loader use also and there was recently a link on here about that and maybe someone else will post that. Lots of 3010s out there but hard to get some to part with a 2510 or 2520 and once you run and own one you will know why. I saw a nice 2520 on a lot in town the other day that I plan on checking out again. They are nice handy all around chore tractors.
love my 2510
05-24-2006 17:25:53
 Re: JD 2510 or 3010 in reply to Glen in TX, 05-07-2006 13:35:11
I have owned a 2510 gas for several years now, It has been the best tractor I have ever owned.
