730 diesel with 2 speed transmission?
TDS
05-07-2006 11:45:08
I recently bought a late modle 730 deisel and when i drive it the gears are extremly fast, i mean fast. I was just wanting to know if they where built with a two speed transmission ( high and low). IF they weren't, than whats wrong with my tractor. Thanks in advance.
TDS
Ferd
05-08-2006 08:04:39
 Re: 730 diesel with 2 speed transmission? in reply to TDS, 05-07-2006 11:45:08
Some 730 tractors were ordered with an optional gear set that did not have a creaper gear - first was about the same speed as second and fifth gear was geared different and reverse is also faster. If R, 1,2,&3 are on the left side of the quadrant, it has the optional gear set.
Bob
05-07-2006 11:50:41
There is a 2-range shifter that's built into the gearshift.
As you shift down into the lower gears, the 2-speed is shifted into low by the movement of the gearshift lever into the area of the lower gears.
It sounds like a problem with the shift forks/shift rails causing the 2-speed to remain in "high" when it should be in "low".
