12/24 relay in 730D
mjbrown
05-07-2006 08:18:13
I bought an Orpin 12/24v relay for my 730D and finally got it hooked up after trying to figure out the directions. I thought it looked a bit wimpy for the job and I was right. On the first attempt to crank the engine the relay welded itself in the 24v mode with the engine cranking. (fuel off). After a few seconds of frantic cutting of wires I got it shut off. So back to square one. When I got the tractor it was wired with two 12v batteries in series with an alternator that had some sort of thermal cut out so it would charge for a bit then cool off. That alternator was cooked so I put a 12v generator on it and manually switched the battery connections back and forth.
Richard J. Heath
05-08-2006 12:59:06
 Re: 12/24 relay in 730D in reply to mjbrown, 05-07-2006 08:18:13
How about a 12/24 volt trolling motor set up. for running the batteries are in series but the charge plug parrels them. Shouldn't be hard to copy
Mike M
05-07-2006 19:20:07
I think this may be why they built alot of bank barns in Ohio,those banks work great to coast start these old diesels. FYI in case all else fails.
Bob
05-07-2006 08:44:09
Why not put it back as Deere intended, and either get a working 24-Volt OEM-type generator, or a 24-Volt isolated ground alternator?
Even going to a 12-Volt starter would be better than the extra layer of complexity added by the series-parallel switch.
Or, if you insist, there are heavy-duty series-parallel switched that are up to the task. Need some part numbers?
mjbrown
05-07-2006 13:01:47
 Re: 12/24 relay in 730D in reply to Bob, 05-07-2006 08:44:09
I don't have the original generator etc. The tractor had thhat stuff removed before I got it. I looked at 24v alternators on line and they were pricey. A heavy series parallel relay would work.
If you wouldn't mind posting part no.s that would be great. Thhanks
Bob
05-07-2006 13:23:30
 Re: 12/24 relay in 730D in reply to mjbrown, 05-07-2006 13:01:47
I'll get the #'s for you tomorrow, as I have then at the shop. Also, if I can find them I should have a good 24-Volt generator and regulator I'd sell reasonably. I also have a 24-Volt alternator and regulator or two lying around.
