4020 '68 synchro question
Nylon
05-06-2006 22:51:26
I know I have a hi and low reverse in the 1,3 R as well as the 2,5,R. Today I was using 4,7 and 6,8. I went too far with the 6,8 and ended up in the R position and I started to reverse. I stopped right away thinking that wasnt right. I went down to 4,7 and tried the R position and I also had a reverse there. I didnt let it all the way out for fear of tweaking something.
Is there a reverse in these positions? Or do I have something very weird going on here?
Thanks,
John
Nylon
05-07-2006 21:44:27
 Re: 4020 '68 synchro question in reply to Nylon, 05-06-2006 22:51:26
I have a reverse on 4,7 and 6,8 as well as the 1,3 and 2,5. Is the third reverse common to both of these hi lo gears (4,7 and 6,8)?
Thanks,
John
msb
05-07-2006 20:28:00
That third reverse was responsible for a lot of 10 series transmission cases to go to the scrap dealers far too soon. It wiped out the lower shaft bore in the case.Deere used a bushing because there was no room for a bearing on the shaft and the bushing couldn't handle the torque.Since most farmers plowed in fourth gear and they had trip bottom plows,it was only natural to use the 3rd, reverse to reset the plow bottoms and inveribaly that was the story we heard when their transmission went kaput. That was the only reason Deere blocked out the 3rd reverse.
Nylon
05-07-2006 14:28:03
Well Thanks for the good information guys. I have no need for a reverse that is faster than the 2,5,R speed either. I do have a need for a reverse that is slower than 1,3,R speed. I have to ride the clutch when blowing out snow banks after plowing and that is not good. The 4020 would handle the speed/power but shear pins cant keep up at pto speed on 7 foot blower in dense pack bank snow.
There was an auction up here on sat that I wanted to get to as they had a 1066 hydro up on the block. Needed engine work..also had a 966, 1466...all 3 with loaders and cabs. Also had a 460 with loader up for sale but already have one of those. The 460 blows snow fine but without the cab it is no fun...but even with the T/A in low reverse it too is a bit fast. Trouble with the 4020 is that it starts fine to about 22 degrees without heat. And down to about 10 degrees it will start with heat but after that It wont even think about starting. Anyway sorry to ramble.
John
Glen in TX
05-07-2006 13:50:50
Like Jim said they did have 3 reverse speeds in 4010 and 5010. I'm not sure about the 3010? They blocked those off later because most people didn't have a need for them. Those also caused too much clutch burning too because of someone riding the clutch while trying to back up to something. A fast reverse when not needed is kind of dangerous. A 5010 didn't really need the 2nd reverse speed let alone a 3rd one. JD called those 3rd, 5th, and 7th reverse because they were shifted down to R in those ranges. This is max reverse speeds shown in 5010 manual using foot throttle at 2500 RPM.
3rd reverse = 4.5 mph
5th reverse = 7 mph
7th reverse = 12 mph
Dad told us if he ever caught us in 5th or 7th reverse at full throttle we were in BIG trouble so I never tried them and we had no need to. lol.
Tx Jim
05-07-2006 04:03:02
John,4010's had more reverses available when new than 4020's because JD blocked off higher speed reverses in 4020's but yes they are still obtainable on 4020's if you have a "need for speed in reverse". Tx Jim
