4320 guru needed!
rickoney
05-06-2006 19:52:24
Hello all,
I have a 4320 that keeps shutting down. It is as if I simply turned the key off. It started a few months back and only happened once in a while. However, it has continually grown more common, to the point I can only now move 5 feet! It will start right back up immediately after quitting. So far I have changed the fuel filter, fuel transfer pump, injectors, and seals in injector pump (it was leaking fuel into the crankcase). I also have a slow intermittent discharge in the electrical system. After a week sometimes the battery is dead, sometimes it isn�t. I don�t think the illnesses are related, because I started the tractor and disconnected the electrical system directly from the battery and turned the key off. I had a jumper in place from the battery to the injection pump to keep the relay open. However, is still quit. I believe the relay to be in working order, I can hear it close when I turn off the key after it has quit. So essentially I isolated the complete electrical system and it still quit. I am starting to think the injection pump is the culprit. Does anyone have any thoughts or suggestions? Is there an easy way to check the injection pump on the tractor?
I appreciate everyone�s help.
rick
Matt in PA
05-07-2006 07:20:06
 Re: 4320 guru needed! in reply to rickoney, 05-06-2006 19:52:24
Hello,
I have a 401C TLB(basically a 2030)that I had the identical fuel problem with. Replaced everything in the fuel system to find out that the injection pump ate itself. I am not familiar with the pumps on a 4320, but if you find a filter screen on the pump or pull and injecter line and find what looks like coffee grinds then your pump is shot. As for the electrical problem I am no help. Good luck!
jdjerry
05-07-2006 06:59:44
I had a cigaratte filter in my fuel inlet. It would stop the tractot dead. I bought the tractor 5 years ago and the pump had just been rebuilt and it never bothered till this spring.
johns48b
05-07-2006 05:42:34
some of the guys working for me lost the top to my fuel tank once and stuffed paper towels down in the filler neck. the towels got wet and fell into the tank and you talk about a mess to get out. check to see if there is something stopping the fuel line up going to the pump too. sounds like the other guys have it nailed though.
Tx Jim
05-07-2006 04:15:57
rickoney,you mentioned having installed a jumper wire to injection pump. If fuel at injection pump is controlled by electricity then fuel cut-off in pump can be at fault. Remove fuel control switch and re-istall without little cut=off plunger and spring. If this lets engine continue to run then you need new cut-off valve. Downside is you have to kill engine with brakes in 8th gear. Tx Jim
430WLPG
05-06-2006 20:36:30
If it has a roosamaster pump on it ,it sounds to me like you have a restriction in the pump return line,probably you can remove the fitting on the top of the pump where the small line hooks and it will be stopped up with some black plastic pieces,there's a drive plate inside the pump coming apart,Any way clean this out and it should run until it plugs again, also there is a glass check ball in that fitting that you can break out and the trash will return to the tank and will run quite awhile longer ,But you will have to rebuilt the pump eventuly. Hope this helps
msb
05-06-2006 20:33:02
Remove the fuel line to the fuel pump to see if there is free flow of fuel from the tank to the fuel pump.
If that proves out then I would suspect the plastic governor weight retainer seal has disintigrated inside the injection pump.Pull the timing window off the side of injection pump(2 screws) and look to see if there is a lot of small black plastic pieces inside,its time to have the pump overhauled if that is the case.Ask the rebuilder to replace the weight retainer with the new one that doesn't have the plastic seal in it.
You will never tell the difference in engine performance and you will never have to have the pump rebuilt because a plastic seal went to pieces.Definitely not one of Roosa Master's better ideas.Thay might have kept Deere's business a while longer if they had done this back in the early 60s.
There were several things Deere engineers didn't like about the German Bosch pump they used on the 4430 and up, but reliability WAS one thing they did like about it.
The Roosa Master pumps needed to be rebuilt every 3 years with hard field work and Deere wanted to get away from that inconvenience for their customers.The heat made the plastic brittle.Roosa Master changed the makeup of the plastic material two or three times,but never solved the problem until they did away with it.
rickoney
05-07-2006 15:58:26
 Thanks, the pump is shot in reply to msb, 05-06-2006 20:33:02
Thanks to everyone for all the information, my dad pulled the cover and found a bunch of black plastic (not good). Does anyone have a place to get the pump rebuilt? We want to get it right the first time and a fair price.
Thanks,
Rick
msb
05-07-2006 20:35:57
 Re: Thanks, the pump is shot in reply to rickoney, 05-07-2006 15:58:26
There are lots of people who think they know how to rebuild those pumps.I know better.I had extensive training from Deere on those pumps as well as working on them in a qualified diesel room for many,many years.I no longer have the access to a test stand that is required to do the job right.Deere got out of the parts business on the pumps and the dealer sold the test stand.Take it to an authorized Standedyne(Roosa Master) repair station for the best possible job.
