2510 Hold Back Going Down Hill
Paul in WI
05-06-2006 19:52:00
I have 2 - 2510's and a 2520, all diesels. The 2520 and one of the 2510's hold back well when going down hill. The remaining 2510 does not, going down hill the engine will be driven to high RPM even when the throttle is in the low RPM position. Can anyone explain why these tractors behave so differently when going down hill. The 2510 does have a different type of injector pump on it. Could it be the pump? Could it be injector pump timing? Any diesel experts out there? Thanks ahead of time. Paul in WI.
msb
05-06-2006 20:38:49
 Re: 2510 Hold Back Going Down Hill in reply to Paul in WI, 05-06-2006 19:52:00
You need an expert injection pump rebuilder.Sounds like the governor link is out of adjustment on the one tractor.Probably the governor is a bit sluggish when a load is applied too? Not a snappy response is it?
