'37 BR trouble
JRB
05-06-2006 18:18:43
Hopefully sombody's got an idea what may be wrong here. I've got a '37 BR, bored .045" over w/ NOS pistons. Carb's been overhauled (twice by two different & reputable shops), mag is a Wico C and has also been rebuilt by a reputable shop. Governor was rebuilt and works fine. This tractor will start on the 1st or 2nd turn every time. It will also idle fine. If I throttle it up at anything more than a snail's pace, the thing starts coughing, backfiring through the aircleaner making black smoke and then backfires through the muffler and dies. It will still restart relatively easy after this. If I throttle up slowly, it will run decently. Under a load (we pull an 11' reel mower gang) it will run along fine until you go down hill (lessen the load on her) then she backfires and dies. I'm fairly capable (no expert) as far as adjusting the carb and have been talked through it several times and have adjusted it in the same manner as my '37 BR and other tractors. Is it possible that this is not a carb problem??? The only part of this tractor's engine that I'm not 100% sure of the quality of work is the cylinder head. Could my trouble be in valves / guides / seats? I'm beginning to think I may just have to shoot her! Thanks.
Duane Larson
05-06-2006 21:16:32
 Re: '37 BR trouble in reply to JRB, 05-06-2006 18:18:43
JRB,
Well, I'll share a couple of thoughts - is your governor linkage to the carb properly adjusted? With the carb butterfly wide open and the throttle lever in the wide open position the governor rod at the entrance to the carb throttle lever should be one-half of the hole short (ie, you have to pull the governor rod 1/2 of the hole diameter to insert the rod in the hole).
I would check the fuel level in the bowl using a 1/8" NPT hose barb and a piece of clear plastic tubing which fits over the hose barb. Remove the drain cock in the bottom of the carb fuel bowl and insert the hose barb, hold the tubing up along side the carb bowl, and with the engine off turn on the fuel. The fuel level should be 3/4" below the top of the bowl.
Are there any restrictions in the air flow to the carb - plugged air filter, or some such?
Is the running timing correct? If it starts good the starting timing is ok, but wear in the impulse cup and associated impulse plate can change the running timing. This can easily be checked with a timing light, and a search of the archives will give several discussions of timing an unstyled tractor with a timing light.
A compression test and a blow down test may be useful in checking the head/valve system - were the valve spring tensions checked?
I assume the carb overhauls have checked that the correct nozzle and economizer plugs are in place and in good condition, and the nozzle spring is in place.
Other things like copper spark plug wires, good plugs, and proper and adequate fuel flow should also be verified.
BMAN
05-07-2006 06:23:01
 Re: '37 BR trouble in reply to Duane Larson, 05-06-2006 21:16:32
I think I would try a different carburetor and magneto from another tractor that runs good. Try one thing at a time just to be sure.
JRB
05-07-2006 05:43:53
Duane, thanks for the tips. The throttle linkage is correctly adjusted as is the timing (as far as the flywheel/timing mark are concerned) I will, however, check the float level and change mags to rule out an internal problem with the magneto. I run Autolite 3077 plugs and have been happy with their performance in other tractors. I think I'll send the head to the machine shop I've been using lately as their work is very, very good. They can evaluate the valve spring tensions. Any other ideas?
