68 3020 gas stalling
kurt keeler
05-06-2006 09:26:25
My 3020 gas has been stalling on me. I've checked the spark right after it dies and spark is good. Fuel flow is good (bowl is full and fuel pump is pumping good flow).
The other day I let the tractor run with the hydraulic pump bypass set so the hydraulic pump would not run and let the tractor warm up. I then set the bypass to run the pump and the tractor died. I repeated this test a couple of times and it appears that the hyraulic pump is causing the engine to die. Has anyone heard of this before? My pump is not shot is it? I am going to change fluid and filter to see if that corrects the problem.
kurt keeler
05-07-2006 09:00:56
 Re: 68 3020 gas stalling in reply to kurt keeler, 05-06-2006 09:26:25
I'm not sure what you mean about the nature of the beast, but this problem has been ongoing and makes the tractor only usable for short times. After it dies I have to wait a while before I can get it started.
I'm tempted to just sell the damn thing and get something that works. I don't need a "project",,, I need a usable tractor.
msb
05-06-2006 21:12:30
You can change the oil,but don't expect it to help.That is just the nature of the beast.The governor is a little too aggresive and pops the throttle plate open too far,too quickly.Not much you can do about it except be ready to pull the choke on a bit.What you might do is check the governor linkage.It should be a half a hole short with both the governor and the throttle plate in the wide open position.The other thing you can do that might help is check the distributor advance mechanism to see if the springs are still hooked up and the weight are free to move.Lighly lubricate the pivot points and anywhere the weights rub.If you have a repair manual and a timing light you can check the advance to see if it is within specs. The last thing is your carburetor accelerator pump could need some attention.
