JD 2350 leaking seals
LDP
05-05-2006 14:34:44
I have a 2350 that leaks hydraulic fluid at the rear bottom of the tractor, by the seals where the lift arms attach to the tractor. I have replaced the seals and they still leak. I was wondering if I need a new shaft. Is this shaft hard to put in? Can you just tap the old one out and drive the new one in? THANKS!
daryl kennedy
05-06-2006 04:32:19
 Re: JD 2350 leaking seals in reply to LDP, 05-05-2006 14:34:44
its quite simple to replace they just slide in and out the only problem we had was the tires were set in too much
we had the same problem with the lift arms leaking down the shaft is expensive though
