Installing the distributer...Timing the motor 3020
TDS
05-05-2006 12:08:42
i removed the distributer on my 3020 gas, to paint and sandblast it. During the process i turned the end of the crankshaft so the motors not at the same time as it was before. What do i do to put it back into time. I dont have a copy of the ownersmanual at this time. The tractor is a 1964 John Deere 3020 gas, powershift. Thanks in advance.
TDS
Bob
05-05-2006 15:50:50
 Re: Installing the distributer...Timing the motor in reply to TDS, 05-05-2006 12:08:42
The distributor drive and the oil pump gear have an offest slot and drive tang. The distributor will only go in one way, back the way it was before you took it out.
Now, if you have removed the oil pump, that is ANOTHER matter.
