Governor heel backlash
730 Mike
05-05-2006 10:30:48
I am having trouble getting my gov. back together. When installing gov shaft and fan shaft the shafts get tight and the bolts are still loose. I do have all the shims and gakets in that came in the gasket kit. Looking in my parts book it appears I have all the parts installed correctly. And according to my tech manual everything should be right. Tech manual is for a 720D and I have a 730D tractor but it looks the same as far as parts go in as to what I have.
Thank You Mike
Mike M
05-05-2006 12:11:06
 Re: Governor heel backlash in reply to 730 Mike, 05-05-2006 10:30:48
If everything is pressed on into the proper place then it sounds like you just need to get more shims so you can get started to adjust it ?
