3010 Junk in the oil
Steve/IA
05-05-2006 06:46:09
I have a tired 3010 gas that should have had an overhaul years ago but since I only use it with a 7' finishing mower and snow removal it still has plenty of power for my needs and I'm cheap so I haven't spent the money. I change the oil and filter very frequently but the last couple of times I have noticed a bunch of yellow/orange flakes that look like paint chips in the filter can. What are these chips and is it a sign I need to pony up some money for the old girl?
MSM
05-05-2006 11:30:14
 Re: 3010 Junk in the oil in reply to Steve/IA, 05-05-2006 06:46:09
Could be paint from the inside of the engine block, some were painted a yellowish-orange inside,the same as the trannsmissions were.
Bob
05-05-2006 07:53:54
Sounds like bearing metal. One source, in addition to the rod or main beariings, could be the crankshaft thrustwashers.
Steve/IA
05-05-2006 07:58:35
 Re: 3010 Junk in the oil in reply to Bob, 05-05-2006 07:53:54
It will not stick to a magnet so I don't think it is bearing. What are the thrustwashers made of?
Bob
05-05-2006 15:57:13
 Re: 3010 Junk in the oil in reply to Steve/IA, 05-05-2006 07:58:35
I was thinking of "trimetal" bearings that have a layer of copper beneath babbit.
However, Deere tends to use aluminum-lined inserts. I don't know for sure what would have been in there originally, or what aftermarket bearings could have been used in a rebuild. You can read about bearing metals at the link below.
Bottom line, as the other guy said it could be flakes of coating from the inside of the block, or possible copper or brass from the bearings.
You should be able to tell if the flakes are non-ferrous metal, or paint.
