830E fuel tank removal
830
05-04-2006 18:48:08
How is best way to remove fuel tank from a later 830 electric w/power steering (to clean)? Have tin work off top, but now parts of steering shaft, gearbox, etc on top. Take steering pieces off (where split)? Take a tire & fender off & slide out side? Side out to rear after removing instrument panel??
WeirdDeere
05-05-2006 00:20:37
 Re: 830E fuel tank removal in reply to 830, 05-04-2006 18:48:08
I was able to remove the fuel tank off my 80 (it has powersteering) from the rear. I had to remove the instrument panel, gearshift, AND I think the quadrant (gear pattern piece). It was tight, but made it out. And back in the same way.
You could remove the steering column, but that would distirb some very touchy powersteering settings. Not to mention that the column alone weighs approximately 5000 pounds! Ha ha.
Don't forget to look at your fuel shutoff valve. Mine leaked externally, and I had to repack it.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
