430 rockshaft repair
dpmiller
05-04-2006 18:26:42
Dual touchomatic, left shaft (outer) slid out while replacing seal. Does anyone know of the method to reinstall? Having trouble sliding splined shaft into splined collar inside housing.
Thanks,
Dave
James Nauert 420W
05-06-2006 18:29:22
 Re: 430 rockshaft repair in reply to dpmiller, 05-04-2006 18:26:42
There is only one way to slide the shaft into the hollow one. There is a master spline that needs to line up, even with the rockshaft off the tractor they are tricky to line up and get back together. I put new seals in mine and it didn't stop the leak i would bet most of the time it wont.
buickanddeere
05-06-2006 06:33:18
Even a new seal may not stop the leaks. The housing is likely worn. The answer is to tear it apart and machine the housing for the late 330,430,435 and 1010 bushing upgrade and new style seals.
Henry M
05-05-2006 11:30:30
Dave
My thoughts on pulling the back housing is that you better do some checking first on that model. The tom (touch o matic) should have four positioning lugs under it that fit down into the top of the tranny housing. Two of them might be on the rockshaft housing. So if that is the case it will be time to pull the tom.
I am gonna be quiet now or it will sound like I been there on a late model 420 which is sposed to be the same as a 430.
Mike M
05-05-2006 07:08:56
Not sure but it sounds like what happened to me when I tried to take a short cut to the book on an MT by not removing the housing from the tractor first. It slid out too far and dropped down and the only way to get it back together was to go ahead and pull the back part of the housing off just like the book says. This way you can line it up from the insides.
Henry M
05-04-2006 18:47:28
Dave
I think we are gona have fun. As I recall those shafts are splined so that they only fit one way on the crank inside. Maybe if you had a borescope or the like you could peek in there and figure out a way to get things aligned. I havn't heard of a trick way yet.
I think the crank that that shaft fits into also fell down a certain amount when the shaft cleared the crank.
YOu must be taking about the hollow shaft?
