Felt for flywheel cover on 49 B
TBJ
05-04-2006 08:36:14
I need a gasket or felt for the flywheel cover on a 49 B. JD A3311R, local dealer cannot locate it. any help would be appreciated. Maybe something else can be used. Thanks
Kurt_JDB
05-05-2006 11:24:27
 Re: Felt for flywheel cover on 49 B in reply to TBJ, 05-04-2006 08:36:14
This discussion was very timely, as I was just about to go looking for the flywheel cover felt and gasket. I just got off the phone with my local JD dealer, these parts are available, and on their way to me.
Thanks,
Kurt
TBJ
05-05-2006 03:52:45
Thanks all, my local JD dealer had rather sell lawn mowers thsn parts.
Pete in MD
05-04-2006 18:28:24
TBJ, I just checked "JD Parts Homepage" and found the felt(A3311R) available at $2.60 and the rubber packing on the backside of the flywheel cover(F2728R replaces B2550R) at $7.50.
Maybe your JD parts man needs a kick in the a..
Glen in TX
05-04-2006 22:00:39
 Re: Felt for flywheel cover on 49 B in reply to Pete in MD, 05-04-2006 18:28:24
Well, GOOLLLLYYYYY LOL. I only checked it leaving the R off end and figured a JD parts man could have forgot that? or at least found real number? lol. Yep it's there but do they really have it?
Part Details Part Number: A3311R Part Price: 2.78 USD On Hand: 0 Check Other Stores Description: FELT, FLYWHEEL COVER
Part Details Part Number: F2728R Replaces Part: B2550R Part Price: 8.03 USD On Hand: 0 Check Other Stores Description: STRIP, PACKING
dennis cotton
05-04-2006 13:40:18
third party image
I got some felt with adhesive on one side from mcmaster carr that worked really well. they also had some rubber material that i used to go on the cover as well.. dont have the numbers but a search should turn them up..
dennis
and here is a link to the rubber part Link
NortexJD
05-04-2006 11:50:54
Thanks Glen. I removed the cover to take off the starter, also suspected the flywheel seal was leaking. Noticed the ring gear was also worn badly. Now I gotta remove the flywheel. Guess I can kill several birds with one stone once the flywheel is removed. Let's see: rebuilt starter, new ring gear, new crankshaft seal. Might as well but a new battery cable on as well. Anything else I need to look for after I get the flywheel pulled?
Glen in TX
05-04-2006 09:55:03
Yep, number shows invalid. Try finding some felt by looking in yellow pages for a gasket company near you. Many industrial bearing supplies can get or stock felt also. Hobby shop felt will probably all be way too thin. For the other rubber strip you might find some weather stripping at a local auto supply or body shop.
BTJ
05-04-2006 10:40:54
 Re: Felt for flywheel cover on 49 B in reply to Glen in TX, 05-04-2006 09:55:03
Thanks Mike and Glen, I will check this out.
Mike M
05-04-2006 09:35:32
If that's the one across the top then just some plain old felt strips will work. If it is the rubber one that goes down the side around and over the tranny side cover then that stuff was a special shape and I don't know what would work good. My gasket sets had some new ones in them but this was quite a few years ago too.
NortexJD
05-04-2006 11:08:14
 Re: Felt for flywheel cover on 49 B in reply to Mike M, 05-04-2006 09:35:32
Just removed the flywheel cover off my A and it didn't have a gasket on it. When I pulled it off about a half quart of oil came out with it. I am thinking this was coming from an old crankshaft seal. Is the flywheel cover seal a necessary item?
Mike M
05-04-2006 12:06:54
 Re: Felt for flywheel cover on 49 B in reply to NortexJD, 05-04-2006 11:08:14
Most are missing them I think they may help if it sits outside.
Glen in TX
05-04-2006 11:27:35
The felt and seal were on cover to keep dust, dirt and trash out and not hold oil in. That's why felt on bottom so if leaking crank seal it could seep out some but over time it either plugs up or falls out. Probably also cuts down on some vibration of cover too.
