1940 JD B Help to stop IT
ironHorse
05-04-2006 05:35:40
In stead of letting it run out of gas like the owner manual say or choking it out is there a simple way to hook up a kill switch.
unclebuck
05-05-2006 17:34:32
 Re: 1940 JD B Help to stop IT in reply to ironHorse, 05-04-2006 05:35:40
I still use the tried and proven shut the gas off and let it run till it dies..... that way you know the fuel is off and you wont ruin 2 gallons of good oil!
johns48b
05-04-2006 19:03:30
i just drilled a hole in my distribuator cap and ran a wire from the (i think) the points to a plan toggle switch that had one leg fasten to ground. i don't remember if thats right or not, but i know i had a wire running from my mag to the switch and then to any ground. lol
CMB
05-04-2006 14:01:22
I've been operating 2cyl JD's since the mid 1940's. We always just idled the engine as slow as possible, put them in gear & while holding the brakes, engaged the clutch & killed them. Don't remember ever shutting the fuel off, but that would be a good idea in case the needle valve leaked & filled the engine with gas.
dab
05-04-2006 08:27:11
What type of mag do you have?
dab
05-04-2006 05:48:42
If it has a mag you should be able to hook up a ground wire to it. At least on a type CD mag you can. I would still shut the gas off though. Good safty measure incase of a stuck float.
ironhorse
05-04-2006 05:52:20
 Re: 1940 JD B Help to stop IT in reply to dab, 05-04-2006 05:48:42
sorry to sound dense but where do I hook the ground wire to?
van robinson
05-04-2006 20:10:14
 Re: 1940 JD B Help to stop IT in reply to ironhorse, 05-04-2006 05:52:20
Just hook the ground wire to any part of the tractor. You can put the wire around a bolt and tighten the bolt on it, under a nut, wrapped around a screw, anything that is attatched to the tractor. I think the idea of idling down the tractor, holding the brake and easing off of the clutch would be your best bet. Course, you could always pull the plug wire going from the mag to the distributor cap. If I want to kill my "40 B and use it again soon, I do the brake and clutch method. If it is going to be awhile before I use it again, (day or so) I run it out of gas.
Glen in TX
05-04-2006 09:34:38
Which mag do you have? Wico C or XH ? Those had a kill terminal on side for a wire and also a strap stop button could be installed. Many had those on them but for some reason many of the Wicos on JDs didn't so you would shut the fuel off I guess. If you don't see a 10-32 screw sticking out the side then it doesn't have one but we do have kill terminal kits available to put on them. Just takes drilling a 1/4" hole in right place and installing. On the Wico C will have to remove the coil and all to do it though. If you need a terminal kit and instructions email me. I install them on all rebuilds now just as a safety measure.
WICO XH-1042 with stop terminal:
third party image
