49 G carb
Jeep 65
05-03-2006 20:33:35
1949 G we have to run a little choke for this G to run half way good. We are going to rebuild the carb, what should we be looking for to cause it needing some choke to run good. I know some of the passages effect the Idle. Some Ideas would help while we have it a part. Thanks
Jeep65
05-04-2006 10:18:29
 Re: 49 G carb in reply to Jeep 65, 05-03-2006 20:33:35
Thanks guys, I am planning on cleaning all the passaged, I was just looking for info so I don"t miss something. I didn"t know if there was a particular area to check for the need for choke to be on some.
Ravgardner
05-04-2006 08:22:26
Could it be an air leak between the carb and the manifold? Start the tractor then spray some WD 40 on the gasket area between carb and manifold and see if this causes and change in the way it runs. It may just be a bad gasket.
P Browning
05-04-2006 07:49:32
Jeep 65 -- There is a quick, no-wrench test you can perform to tell you if the idle (or load) passageways are closed. Run the test to see what you end up with. As for the fuel nozzle, Field Service Bulletins 153-S (6-15-46) and 182-S (August 51) have some really great data on the G & GM carburetors you may benefit from. Contact me for more on those by going to www.jdhpubs.com and using the contact me buttons. Here is the passageway test procedure: - - - - -
Testing -- LOAD and IDLE Pathways -- A test is conducted to double-check your carburetor's IDLE and LOAD pathways by manipulating the IDLE and LOAD needles. Here is how it goes:
NOTE: This test involves radical adjustment of both the LOAD and IDLE needles. Before you start the engine, observe the position of each needle lever, and count the number of turns OUT that each of the two needles is at so that you can put them back where they were before this test is run.
Warning: When turning a LOAD or IDLE needle all the way in, take it gently as the needle bottoms out. Going up against the stop with too much force will damage the needle.
(1) With the tractor running at least at roughly half-throttle, turn the LOAD needle all the way in. The engine will continue to run if the IDLE SYSTEM is open, and if it stops running, -- the idle system IS NOT open! Assuming this test is a pass, reset the LOAD needle where is was and go on to test two below.
(2) With the engine running at Fast Idle (full throttle - no load), turn the IDLE needle all the way in. The engine will continue to run provided the LOAD FUEL system is open, however, in this mode, engine operation will be a throttling pattern. As engine speed drops, the governor will open the throttle to draw LOAD FUEL because the idle path is closed. This pattern, however, indicates the LOAD FUEL channel is open and working as it should. If the engine stops running, the LOAD FUEL channel is blocked.++++
John T
05-04-2006 07:10:08
Jeep, from your description of needing a lil choke to run right, I also suspect plugged up idle pasages regarding at idle or a plugged up nozzle regarding running at RPM or under a load.
THEREFORE the main things I would be sure and do is:
Remove (often requires making a puller) the main center vertical brass nozzle and clean all its lil side holes and buff n polish it all. The lil spring in the bottom center of the bowl is to hold the nozzle up in place.
Remove each n every brass drill plug (may need to heat gently just until it shows the funny green off color) and use the extra long No 40 and No 53 aircraft drill bits (available from Roberts Carb Repair) to clean n drill out the idle passages located behind them. Use the right bit for the right sized hole and use welding wire etc to clean out the smaller pasages.
Get a good carb kit which usually comes with a new needle valve n seat and clean out the side circular strainer well while youre at it. MAKE SURE the float is NOT a leaker!!!!! !!!!
John T
