5020 cylinder sleeve packings
jd jim a
05-03-2006 19:23:52
I'm in the middle of overhauling a early 5020. When I took the engine apart, I only found one thin square packing on each sleeve. There are no grooves in the block. Is this correct? It scares me a little that this one little packing is expected to do the job.
430WLPG
05-04-2006 16:53:18
 Re: 5020 cylinder sleeve packings in reply to jd jim a, 05-03-2006 19:23:52
A guy I know that had a 5010 and he rebuilt it and he said that John Deere had a special tool that was passed around dealer to dealer that would cut a groove in the block.
Glen in TX
05-04-2006 09:41:26
Like Tyler is saying they did a update on them. Later they changed the replacement pistons and liners for 5010 and 5020 to type used in later 5020 and 6030. You can see updated ones listed in parts manual on JD parts book.
TylerARK
05-04-2006 05:13:37
I think there is one o-ring in a groove on the early 5020 engines and the one square packing around the bottom of the sleeve. The later ones had 2 o-rings and a square packing.Take something sharp and dig around where the groove should be and see if you can find it.
Tyler
