1950 A slinging oil from pulley
PA JOE
05-03-2006 18:22:24
My neighbor has a 1950 A that is slinging oil out of the clutch pulley. The local JD dealer says there is no seal inside the pulley, which I find hard to believe. Please help with some ideas on what the problem may be. I am posting because he is 84 years old, and will not go near a computer. Please help.
Greasy hands
05-04-2006 18:58:56
 Re: 1950 A slinging oil from pulley in reply to PA JOE, 05-03-2006 18:22:24
There is a drain hole in the bottom of the dust shield. The clutch pulley must be removed first, then the oil slinger. I took the dust cover off to clean out the hole it is a little hard to find because of all of the old dirt. You might be able to leave the dust cover on and clean it out with a piece of wire, this will save you from buying the gasket behind it.
Pappy
05-03-2006 21:40:38
If it is a 1950 "A", it probably has a drain plug on the bottom of the first reduction gear cover. Drain it out and see what you get. If over a pint of oil, its too much. There should be a fill plug on top of the cover toward the back of the cover. Add one pint of oil. You can look down inside the pipe fitting where you pour in the engine oil and see if anything is clogged up. You might be able to see the hole where the oil returns to the crankcase. Check these before you start tearing it down.
MPK
05-03-2006 19:10:04
There are some drain holes inside to drain the oil back into the first reduction gear cover that could be plugged. To clean them you need to take off the pulley. Also the rear wheel on that side has to be out far enough to remove the pulley.
