Crank For A 36 B
CalJim
05-03-2006 17:03:54
Hello,
I could use some help on this one! My Machinist called today, said my crank was out of round .0035 at the main journals. It is a B114R crank. I have not seen Oversize Main Bearings anywhere, what are my options? Machinist says to bite the bullet and get a Crank and Rod Kit, where can I get one? Would it be cheaper to have the crank built up and reground? Thanks CalJim
phil2
05-05-2006 16:26:21
 Re: Crank For A 36 B in reply to CalJim, 05-03-2006 17:03:54
I'm surprised that someone doesn't sell undersized mains - usually they come in .001 or .002 increments. But if you can't find them, maybe you could use .002 shims to bring a std bearing down by .004 - have the machinist turn it U/S by .004.
J Schwiebert
05-04-2006 18:54:43
Check with a shop that welds cranks and then also can grind them. Get two prices. I checked on a shop item with two shops both do go work and there was a 75% difference in price. J.
Duane Larson
05-04-2006 17:41:06
CalJim,
You might check with Mike Williams, M&J Enterprises, 563-243-4928. He repairs the splined ends on crankshafts and may build them up if that is what you choose to do.
