FB Hydraulic Conversion
Christos
05-02-2006 22:22:07
Hi Everyone, I've got a FB Drill at home that I had intended on converting to a hydraulic cylinder from the original powerlifts (its a 15x7)
However I had mentioned before that they guy in the salvage yard I went to get the lift assembly (from a FB-B), braces and bearings and the a-frame told me that it was a pop in conversion.
Not to kick a dead horse anymore, but it doesn't fit with the exception of the A-frame that connects to the jackshaft - that does fit.
My question is, if I have the center beam straightened out (it has a kink in the middle) is it possible to have that center beam remanufactured into one that would fit?
I would be using the original center beam as the template. I do know I would have to have the beam cut down, which is fine with me, though, would I have to move the piece of steel that the cylinder bolt into? If so how much should that triangular piece of steel be moved to make it fit?
The bolt pattern where the beam meets the frame matches up perfectly which is why I am willing to do this. I do realize that what I want to do is a lot of work, but I am hoping at least one of you all has done something simular. Thank you all for your advice
Christos
Brent in WI
05-04-2006 08:54:06
 Re: FB Hydraulic Conversion in reply to Christos, 05-02-2006 22:22:07
Christos,
After rereading your post I realized that your lift is off an FB-B which I believe is a newer model than an FB. They got smart and mounted the fine seed box in the rear for better access plus some other improvements. There is a good chance that the lift will not bolt in directly as you are finding. I also know that the hitch is different depending on the size of the drill so a 15-7 lift might not fit on a 13-7 drill etc. I have a 13-7 that I reconditioned and a 15-7 for parts and the tonge/hitches are very different.
Christos
05-04-2006 10:01:19
 Re: FB Hydraulic Conversion in reply to Brent in WI, 05-04-2006 08:54:06
Thats right, I'm trying to retro-fit something newer on to something older. Both Drills are 15x7, my FB and the parts FB-B. I tried to get measurements when I went to Tri-Greens Auction on my way home yesterday, but I wasn't able to find an FB that had the hydraulic lift to make comparison measurements.
I do have the dealer setup, the Green Operators Manual that has, the parts, setup and operators manual in one, and the 1954 revised parts manual for an FB.
When I went to go pick up parts from Mama Deere yesterday I got a print out of double acting cylinder lift (from an FB-B), which is what I have.
The FB-B middle bar would work, its just too long by six inches or so for an FB hence, me asking about how to cut and paste the FB-B center beam to make it fit (and work) on my FB.
Christos
Glen in TX
05-04-2006 11:53:05
 Re: FB Hydraulic Conversion in reply to Christos, 05-04-2006 10:01:19
If you can't find the right length irons probably just have to cut the angle irons and reweld somehow or make new angles. I dug out some dealer predelivery manuals for FB-B, DF-B, & FB-A and they show a shorter hitch setup for the smaller drills and longer setup for larger drills. Also one with two angles in center and others with one angle in center. Other manual I have is: OMM20450 Operators Manual for JD Van Brunt Powr-Trol Adapters & Hose Supports for models B, FB, & RB Grain Drills. It shows assembly and parts list in back and gives some of the angles a different part number but doesn't give any lengths on them. It doesn't show the side brace angles in parts list. Also from what it and other manual shows the hitches and lift yokes were changed some after 1950 and made stouter and you might find "151" stenciled on those hitches. If you want more info from this manual email me later. It doesn't cover the FB-B and other delivery manuals I have were for assembly and don't show any part numbers.
Glen in TX
05-03-2006 22:17:04
Doesn't sound like you got the right hitch to me either or it came from a different model drill. Didn't you say before you had a dealer assembly manual? Think I have a assembly manual for the FB and possibly the hydraulic conversion manual too. Yes, they had a manual for that too but I don't remember what it really shows? Can dig it out tomorrow and see if you think you might need info from it. I know on some you changed the whole tongue and center beams or have to do some welding while other later drills just had holes already in the beams and used some bolt on brackets for the cylinders. We took levers off our LZ drills and put cylinders on and it was just a bolt on job with the right parts.
Christos
05-03-2006 22:37:03
 Re: FB Hydraulic Conversion in reply to Glen in TX, 05-03-2006 22:17:04
Actually, yeah if you could find the manual, it sounds like it would be a big help.
Christos
Brent in WI
05-03-2006 20:40:45
Christos,
I don't have a lot to offer here without actually seeing a picture of what you are talking about but I have an FB drill with a hydraulic lift and love it. According to my book the lift assy. was a conversion or add on accessory so if you got an original lift assy it should have bolted right in. Perhaps what you bought was not an OEM lift conversion? One thing that I will admit is they are wimpy in the strength department and I had to do some straigthening of the hitch frame when I bought the drill. The center beam was and is straight. Also if the transport pin is left in and you try to move the cylinder, the tractor hydaulics can create a little problem. Of couurse the previous owner did this and not me. LOL
Brent
