MT, if it hadnt been "rebuilt" I would suspect the main center vertical brass nozzle was still clogged up. Unless they are removed, which can be difficult and usually requires a puller be made, one cant properly clean out all the lil side holes. Another thing which could cause fuel starvation might be the float level is too low, do you have any idea where its set at?? Its possible to remove the bowls bottom drain cock plug and use a fitting with a hose barb to attach a clear plastic line held above the bowl to see the actual float bowl level. I guess you have tried adjusting the top load needle??? I set them around 1 turn out then adjust from there. Besides the carb, it needs a sufficient gas flow supply getting to it in order to maintain sufficient float level under load conditions you know. If you turn the gas on and open the carb bowls lower drian cock plug, a steady stream of gas around 1/16 inch diameter needs to flow out. If not, the needle n seat area may have dirt or crud restricting flow through it. If you removed the carbs fuel inlet line and turn the gas on a steady stream the size of the lines ID ought to flow out if the sediment bowl and any 3 way valves and the tank outlet etc are all good n clear. Sooooo you first gotta insure good gas flow to the carb (tank outlet n sediment bowl and any 3 way valve is all okay),,,,, ,,,,then good flow through the needle n seat (thats the 1/16 inch steady stream out the bowls bottom drain cock plug),,,,, ,,,then the load needle is adjusted (the 1 turn out or more),,,,, ,,,,then the carbs main center vertical brass nozzle must all be clean!!!!! !!!!! !!!!! !!!! If she works okay when choked I still suspect a carb or fuel delivery problem even if it were supposedly "rebuilt" John T
