Correct Carb # DLTX 54
Bobl1958
05-02-2006 13:25:50
Sorry, fellas. The carb # was DLTX 54 that I was trying to figure out what it fit. Sorry for the trouble and thanks for any help. Bob
Duane Larson
05-02-2006 21:14:50
 Re: Correct Carb # DLTX 54 in reply to Bobl1958, 05-02-2006 13:25:50
Bobl1958,
If you can't decipher the number, a measurement of the bore on the throttle shaft and choke shaft ends, a description of the nozzle and choke system, and the number on the economizer plug (if it has one) should pin it down.
Glen in TX
05-02-2006 13:52:49
Sorry Bob, Still not a 54 listed in JD SM2029 or MS/Zenith books either? Tell us if it is a single bore carb or dual induction dual bore and study number again and maybe measure the throat bore. These are all of the DLTX numbers I see listed in JD and MS books:
single bore: 3,5,6,8,10,11,12,13,15,16,17,18,19,24,26,31,33,34,38,39,41,46,51,53,63,67,71,72,73, Dual Induction: 75,81,82,83,84,85,86,94,95,96,97,98,99,101,102
I also took a look in Zenith/MS and not a 64 or 54 listed. The later universal Zenith replacement carbs were numbers: DLTX-107U,108U & 109U so it's not one of those. I do not guarantee no typos here either. lol.
Bobl1958
05-02-2006 14:01:11
 Re: Correct Carb # DLTX 54 in reply to Glen in TX, 05-02-2006 13:52:49
Glen - It's gettin kind of embarissing. It's a single induction carb, & would have a choke rod. I'm going to get a magnifying glass and look tonight.
Glen in TX
05-02-2006 14:19:01
 Re: Correct Carb # DLTX 54 in reply to Bobl1958, 05-02-2006 14:01:11
No prob. Just hope I typed them down right in case someone is having ID problems too. When I got in the MS/Zenith book I found some to add the SM2029 didn't show and that I didn't remember or have a real idea right now what they fit? Anyway you would think those 2 books wouldn't leave one out? Let us know which number you decide and we can easily tell you what it fits I hope? lol
CMB
05-02-2006 13:46:09
Bob, you'd better read that carb one more time (very carefully), there's not a #54 carb either!
Bobl1958
05-02-2006 13:52:00
 Re: Correct Carb # DLTX 54 in reply to CMB, 05-02-2006 13:46:09
Wow, it's hard to see, but I thought I had it that time. I'll look again tonight with a glass. Startin to make myself more curious as to what the # actually is than what it fits. Thanks-Bob
