50 Clutch
Johnny(TN)
05-02-2006 12:00:08
I have a model 50 and all we use it for is spraying tobacco. I was putting down herbicides last week and the clutch wasn't snapping like it should. When I finished I took the clutch cover offf to adjust it and only three of the 18 teeth in the clutch disc drive where still on it, the other 15 were sheared off. Any ideas as to what could have caused this. Last year it had a little raddle when running and the clutch lever off. Should I get a new drive disc or try to find a used one ? How expensive are they? Thanks in advance.
Glen in TX
05-03-2006 12:32:03
 Re: 50 Clutch in reply to Glen in TX, 05-02-2006 22:17:48
Also check with Denglers for clutch drive.
billde
05-02-2006 19:15:10
 Re: 50 Clutch in reply to Johnny(TN), 05-02-2006 12:00:08
By all means replace that drive disc, If it spins on the crank it will be very costly.
Gary Meador
05-02-2006 17:24:14
Thanks Glen for that link about the clutch kits, that is real helpful.
GM
Glen in TX
05-02-2006 12:10:27
Here is one to try:
