JD 503 Rotary Cutter
Tweeter
05-02-2006 11:17:49
I have to change the gear oil in my 503 mower and the manual says: Drain old oil from the plug on the side of housing and fill through the top plug on the housing till the oil drains. I am supposed to add oil till it drains out from the side plug or till it spills out the top plug?
Glen in TX
05-02-2006 11:46:47
 Re: JD 503 Rotary Cutter in reply to Tweeter, 05-02-2006 11:17:49
Looking at JD Parts site, parts book, and 3 different gear cases for the 503 yours doesn't seem to have a true lower drain hole like some do so I think you would fill to that side plug only if that's what your operators manual says ?? Or contact your JD dealer. Does it give oil capacity for the gear case ? Doesn't look like this one has a dip stick on top plug like many had. You wouldn't fill to and over the top plug because the oil is going to expand when it heats up during operation and blow out the vent making a mess. Might have to use a suction gun or vaccumm suction setup with small hose to drain it all out. Pushing it out with air could blow out a seal.
Tweeter
05-02-2006 12:13:49
 Re: JD 503 Rotary Cutter in reply to Glen in TX, 05-02-2006 11:46:47
No, the manual does not say anything about oil capacity.
Glen in TX
05-02-2006 13:58:32
 Re: JD 503 Rotary Cutter in reply to Tweeter, 05-02-2006 12:13:49
Might ask the dealer then. I think they just made those later ones for oil to be topped off and don't want you changing it so they can sell you a new one sooner? Strange they listed 2 replacement boxes in parts list so you know many have probably been replaced.
