EXHAUST PIPE FOR A BOUT A 45 A
jd2830
05-02-2006 09:48:19
I need an exhaust pipe for my a the mounting flange has the holes horizontal rather than diagonal. I just bought a johnson cold gas manifold for my 50 a and this is the type of Pipe that I need.
JD60WH
05-02-2006 18:16:15
 Re: EXHAUST PIPE FOR A BOUT A 45 A in reply to jd2830, 05-02-2006 09:48:19
I have one that you need that i'll sell for $30. call me @ 563-503-1266 if you want it
CMB
05-02-2006 13:57:56
I think "Mother Deere" still has these, but must thing they are gold plated, as the price is quite high. The easiest/cheapest way would be to buy one for a later(pressed frame) "A' with the angled flange, cut it off just ahead of the flange & have someone wire weld it back in the correct position. Actually, I've always wondered why one of the aftermarket suppliers hasn't made available, an unwelded pipe/flange combo, so anyone could make either style as needed.
Glen in TX
05-02-2006 11:53:48
You'll need the pipe with the 4 hole flange like your manifold has and those pipes shown in catalogs were for up to 1940 so unless they have one made for yours may have to modify one some or change the flange?
CMB
05-02-2006 13:51:04
 Re: EXHAUST PIPE FOR A BOUT A 45 A in reply to Glen in TX, 05-02-2006 11:53:48
A four bolt flange exhaust pipe was used on a styled "A" only in 1939. (#477000-488000)This serial# range was essentially an unstyled tractor with styled sheet metal & front pedestal.
Glen in TX
05-02-2006 14:13:42
 Re: EXHAUST PIPE FOR A BOUT A 45 A in reply to Glen in TX, 05-02-2006 14:09:22
phooey... meant it says up to 487999 and also replaces the A36R. Johnson has same bolt pattern as A36R.
CMB
05-02-2006 14:03:54
 Re: EXHAUST PIPE FOR A BOUT A 45 A in reply to Island A, 05-02-2006 11:28:13
A '45 "A" would still have come from the factory as an "all fuel" tractor with a "hot" manifold. Gas burners were only made standard equipment at the time the pressed frame tractors were introduced in mid '47.
Island A
05-04-2006 08:38:00
 Re: EXHAUST PIPE FOR A BOUT A 45 A in reply to CMB, 05-02-2006 14:03:54
Right, but the first post stated he has a Johnsosn Cold manifold on his 1950 A. In 1950 the gasser was available, and I did not think the Johnson Cold manifold would fit that.
Dave
