4010/4020
Glenn F.
05-02-2006 09:33:28
Pssst! Don't tell anyone I'm over here! What are the main differences between these two? Thanks, Glenn
ricedaddy
05-02-2006 18:31:22
 Re: 4010/4020 in reply to Glenn F., 05-02-2006 09:33:28
the 4010 had a 380ci with 84 HP, the 4020 used a 404 with 91.2 HP www.tractor data.com
Bob
05-02-2006 20:14:21
 Re: 4010/4020 in reply to ricedaddy, 05-02-2006 18:31:22
However, you'd be pretty hard pressed nowadays to find a 4020 diesel that hasn't been rebuilt at sometime in the past with 4020 pistons and sleeves, and now has the displacement of a 4020.
Bob
05-02-2006 11:43:58
For one thing, the 4020 has larger axles and wider final drive gears.
Mike M
05-02-2006 10:24:19
I think there is very little at least with an early 4020 the pto setup is about it ? Most should have been overhauled enough by now to have the 4020 parts in the engine. Now if you move up a few more years and find a later 4020 you could have a diff. lock move up some more and change over to a side console controls and a different pto again. Keep adding on more dollars also as the year moves up.
