A Brakes Stuck
Bob in NH
05-01-2006 22:50:35
Anyone have tricks for getting a stuck brake apart? This one got left locked when parked for the winter. Although it was covered by a tarp, it must have still gotten wet with snow. Right brake wasn't stuck, but had enough rust and dust build up so that it woldn't keep the wheel from turning. It's apart now with adjuster soaking in PB Blaster.
I'm hoping that with the rt brake working again, the left may break free. Any other ideas?
johndear
05-02-2006 21:23:02
 Re: A Brakes Stuck in reply to Bob in NH, 05-01-2006 22:50:35
The brakes on my 720 will stick tight if they are left "set" overnight and it is foggy. Shoes stick to drums. Usually all it takes is putting a little pressure against it with the clutch (try to move the tractor) and have someone else bump the drum with a 4 x 4 block of wood. The vibration and pressure make em turn loose. Very aggrivating when it is on the trailer at a show and you go to move it only to find the brakes are locked from that little rain shower the night before.
Bob in NH
05-02-2006 09:23:40
The brake pedal and shaft are free and move with no binding at all. Problem is that the shoes are stuck to the drum. We had this happen once before with the right brake assy and ended up having to use a hydraulic press to get the drum/shaft off of the shoe and casting assy. We ended up screwing up one of the shoes in the process. Backing off on the adjuster hasn't released the shoes either.
41JDb
05-02-2006 05:42:27
Mine was stuck solid as a rock and I got it out with heat and a pry bar moving it back and forth. Once it is out take some sand paper and clean off the rust and she should be good. ( All this with it off the tractor) Al
F-I-T
05-02-2006 01:19:40
Take the whole unit off and soak it in a bucket of diesel fuel, then take it apart, clean everything, lube it properly, re-fit the bushings, etc, and either re-line or bake the lining on a BBQ grill to remove the oil. You might have to use some localized heat on the adjuster. I like Nev-R-Seez there.
They generally don't stick so easily if everything is tight and right.
Frank
Pete/ME
05-02-2006 03:02:57
 Re: A Brakes Stuck in reply to F-I-T, 05-02-2006 01:19:40
About brakes, as I slowly re-assemble my '48 B, I noticed that the (left) brake pedal doesn't return, and is actually quite stiff when moved back. Will this work it's way loose with use? Thanks.
Bob Collins
05-02-2006 05:05:37
 Re: A Brakes Stuck in reply to Pete/ME, 05-02-2006 03:02:57
I've had that problem on several brakes and it is usually the brake pedal shaft that is binding. With the brake unit apart remove the nut on the pedal shaft and remove the pedal. Work the shaft out of the housing carefully so as not to damage the threads on the shaft. Clean up the shaft and bore but don't get too aggressive or you'll end up with more slop than you want. A little lube and it will be like new(er).
billde
05-02-2006 04:31:18
Had the same problem on my 50 after a brake job. Now I have a black brake drum, take it apart and free it up.
