Hi Scott, Just some general ramblings on the subject. In order to keep things as simple as possible, lets suppose, for the moment, that HP requirements are linear based upon mower cutting width. To do this, we will have to put aside two blade vs three blade differences, wind tunnel variations, and individual engine torque and RPM characteristics. All of these come into play, but lets forget about them for right now. A Ferris 54" mower that I have, uses a 23 HP engine. This size deck, with this particular engine does a fine job of cutting overly tall grass at a brisk rate of travel. If linearity applies, then 37 HP would be required to achieve the same rate of cut through the same type of conditions when using an 84" mower. Coincidentally, I have an 84" mower that, up until this year, was pulled and powered by a Ford 681 Diesel that is rated new at about 31 HP. Sure enough, my son would be able to mow right next to me on the Ferris, and, in thick grass, could go just a tad bit faster than the Ford without unduly straining either engine. This makes sense using our linearity rule, that not having 37 HP would put the Ford at a bit of a disadvantage. OK, now lets look at a push mower. It is designed to go at an entirely different velocity than the riding mowers. Again, lets assume some linearity in HP vs cutting width, even though the push mower uses none of its own power for propulsion. If this is so, then a 22" mower that has a 6 HP engine would be equivalent to an 84" mower with a 23 HP engine. The 6 HP engine is just plenty for the mower when used at walking speed, so, the 23 HP, with an 84" cut, would most likely be sufficient when using a gear that gives approximately the speed of someone taking a walk. The 23 HP is probably not too far from what your B is putting out. So,now that we have oversimplified HP requirements, lets make a new corollary of our own. If you have lots of patience, and the appropriate gearing, low HP will work. If you want to git'R done, and get it all finished today, then more HP will be required!
