JD 60 w/55 h plow
Kevin
05-01-2006 16:09:28
I am getting ready for plow days and im in a bit of a tight spot. I am using my power blocked jd 60 and 18.4 38 tires with a 3 bottom 55 h plow. I noticed it gets alittle smokey out of the valve cover beather tube, is this normal or do i have a problem? Second thing is compared to plowing with my farmall h and my masseys this deere feels uncomfortably unstable. Is this normal or is there a secret to taming the beast?
RalphinWI
05-01-2006 19:43:43
 Re: JD 60 w/55 h plow in reply to Kevin, 05-01-2006 16:09:28
First of all I'm not sure why you have such horsey tires on a 60. I think 12(now 13.6)x 38 was the largest tire when new. With some brands of tires, going to 18.4's will jack up the tractor (and hitch) nearly 4". If it is 3 x 14 plow, then from the center of the drawbar to the furrow wheel sidewall should be about 25". In the hills you can shift this either way with a landing lever, but if you shift the drawbar much to the left or right permanently (no landing lever) then you will be fighting the tractor all the time. From the factory I would expect the 60 to have the center of gravity markedly lower and further back than either a IH or Massey. If you are climbing hills with the plow, then a 60 will be lighter in the front than an H or 44. This will be especially evident with those 18.4's even if you have adjusted the plow's hitch linkage.
BushogPapa
05-01-2006 18:41:36
Is the 55h plow a pull-type, or a Mounted (3-Point) type..?? If it is a 3-Point type, you will NEED a depth wheel on the land-side of the plow frame... Without it, you can't hold the plow to any shallow depth.. If it is a Pull-type, you can "Off-Hitch" it toward the Right side of the tractor, and that allows you to have the rear tractor tires set wider... Ron..
BushogPapa
05-01-2006 18:41:30
JD60WH
05-01-2006 17:14:12
Mine did the same thing at our plow. I wouldn't worry the tractor is 50 years old and technology at the time called for a breather tube. That is why it is there. As long as it isn't killing the mosquitos out of all of the pipes I'd use it. I used to have an a that had blowby coming from the breather stack, exhaust pipe AND the transmission! As far as stability, my 60 has an extra wide front and 120"tomato axles so I'm pretty stable :)
