G mag bearing squalling
used to be jame
05-01-2006 15:11:45
I posted a couple days ago about G making a squalling noise. I found the problem today when I pulled the mag back off. The bearing is apparently dry, and the nut holding the spring loaded cup was about to come off from the resulting vibration. I can spin it in my hand and feel it vibrate from friction. Question is, do I have it oiled or greased, or should I have it replaced? I don't know anything about mags, but the play in the bearing/bushing seems minimal.
Thanks,
James Martin
greenmech
05-01-2006 18:28:55
 Re: G mag bearing squalling in reply to used to be james, 05-01-2006 15:11:45
Thanks for the follow up. I would try to oil the bearings or bushings if the mag is otherwise in good shape. I had the same problem with a 38 B. Ron Mn.
Glen in TX
05-02-2006 08:06:43
 Re: G mag bearing squalling in reply to greenmech, 05-01-2006 18:28:55
What ever... Your just talking about $3-$4 bushings and $4-$7 bearing and time or labor to put it in verses ruining a $300 mag ??
R W Wisehart
05-01-2006 15:43:05
I have Wico C and X magnetos serviced and rebuilt if I can be of help. Thanks
Glen in TX
05-01-2006 15:38:44
If you have the Wico C mag it has 2 bushings that are available new. They are sized with a reamer to fit the shaft. If a Wico XH it has a common 6201 ball bearing inside a bearing holder on the drive end and a bushing on other end which are available also. All impulse drive parts are available new for both mags as well. Yes, they do wear out requiring replacement after 50 years! If not a Wico bearings are still available to fix it. If you need information on the parts or mag manuals email me. [email protected]
