4020 Rear wheel adjuster frozen
MaverickM23
05-01-2006 08:45:40
The rack and pinion on our 4020 rear wheels is frozen solid. The three cap screws turn loose but each wheel only has 1 jack screw and neither of them will go in the whole way, but they do come out. Just wondering what the best way to get it free is. Thanks
doomer
05-03-2006 19:23:57
 Re: 4020 Rear wheel adjuster frozen in reply to MaverickM23, 05-01-2006 08:45:40
i have moved way too many wheels and have only broken one wedge and it was on a 3020
1) first jack up tractor and loosed wedge bolts.
2) then tighten push out bolts if only one is present, a wedge bolt will suffice as a second pushout bolt but is not recommended for multiple tread adjustments
3) tap on end of axle with 16 lb hammer and tighten pushout bolts gently tap on pushout bolts with 3-5 lb hammer and wedge bolts but make sure that they are only backed out about 1/2-3/4 inch this is not recommended for multiple tread adjustments but does help greatly. it will eventually mushroom the bold heads, 3020 has this since tread has been moved atleast 100 times. worst case scenario you will break the wedge and have to obtain a new one.
4) time and patience are the primary key.
i have also moved wheels that had over 1200 lb of fuild plus 450 lb cast weights and found that it is of no advantage to back wedge out farther that 3/4 inch and actually becomes more difficult since the wheel tends to bind if not resting on the wedge.
Nylon
05-01-2006 22:22:07
I followed the ltighten jack hit axle end with sledge proceedure as advised by the guys on this column and I got them to come free. I like the idea of cutting a pipe and only hitting the wedge but I had no way of fabricating a precision instrument. AfterI had everything free I used anti seize on the axle shaft, wedges and bolts. $ months later I noticed that one wheel was all the way out at end of axle. Sure enough bolts were not snug and one wheel had walked out on the star gear. Both wheels were a bit loose. I had wheels set pretty far out so that I could grind and paint in the cab wells. But the one whell had definately moved. I still like anit seize after what it took and the uncertainty of success at getting those wheels loose. Just make sure to snug them every so often till they don't snug anymore.
John
matthies
05-01-2006 21:01:57
I know somebody is going to cuss me, but I'll say it anyway. I was a Deere tech for a few years and now have a different job but still work on tractors after hours. The last few wheels removed, I loosed the bolts and tighten the wedge bolts and then bladed the driveway or just drove the tractor around. I haven't spent more than twenty minutes on a wheel to move, from a 630, 4020, or 4440. Beats the heck out of swinging a sledge and I have spent a whole day moving wheels on four wheel drives. Drive them if you can and tighten up once loose and then head for the shop. chris
JMS/MN
05-01-2006 20:11:21
I've posted this before, so it should be in archives, but....here it is again. Find a pipe slightly larger than the axle, longer than the distance to the wedge. Torch out a section of one end, half way around. Other end you weld a half inch thick plate to pound against. Wall thickness of the pipe should be no more than the exposed thickness of the wedge. Drive tractor so wedge you want to loosen is on top. Slip pipe onto axle and whack with a post maul. All effort is put against the wedge, instead of wasted on the axle. One man operation, nothing damaged.
Jason Z in MO
05-01-2006 13:04:13
I'll add the things we had to do to get my 4020 wheels freed.
Jacked up only one side of the tractor with the tire just off the ground. Removed all the clamp bolts outside and inside. Tighten the jack bolts as much as possible. (If you break one, back it off a half!) Seriously, be careful not to break one, it's a real pain to remove. Drive out the pinion gear pin. There should be a hole opposite from the adjustment hex head. It might have a plastic or cork plug. Remove the plug and drive the pin out. The gear will stay in place but just float around.
If you can't get the inner clamp bolts or adjusting pinion pin removed, it should still come loose. Getting all of these loose should minimize the beating.
Next take a large sledge, as Mike said, striking the end of the axle shaft as hard and as square as possible. Don't be worried these axles are very hard.
After a few blows, try tightening the jack bolts some more. Repeat until the wedge is free.
You will want to remove both wedges and clean all the rust before you reassemble. Be sure to clean the threads as well.
You can also search this board as the topic has been talked about in the past.
Hope this helps,
Jason
Not Sure
05-01-2006 16:51:51
 Re: 4020 Rear wheel adjuster frozen in reply to Jason Z in MO, 05-01-2006 13:04:13
This may be a silly question, but in which direction do you hit with the maul? Do you hit down on the axel or in? I am thinking hitting in could cause some problems.
Jason Z in MO
05-01-2006 19:50:01
 Re: 4020 Rear wheel adjuster frozen in reply to Not Sure, 05-01-2006 16:51:51
You hit the end of the axle. Just like hitting the end of a hammer handle to drive the hammer head on tighter. In this case the wheel slides off the wedges instead of getting tighter.
I was reluctant when I heard this too. But I was reassured this IS the procedure taught at the John Deere tech schools. I wouldn't do it on the earlier two cylinders. I have had the final drives off my 4020 and they are BUILT.
Mike M
05-01-2006 09:44:24
Can you take the one jack screw from the other side and then put 2 in the side you need to move ? Or are the holes stripped ? If you can put some pressure on the jack screws after loosening the 3 retaining bolts then hit the end of the axle as square and as hard as you can with the biggest sledge you can swing. This really helps pop them loose. If you get it loose you will need to remove the wedge so you can drop the adjuster down away from the rack teeth in the axle so you can move it. If you remove the whole wheel and soak the little adjusting gear in penetrant oil then I have had real good luck freeing them up with a 3/4" impact and working it back and forth until it spins freely.
MaverickM23
05-01-2006 12:26:24
 Re: 4020 Rear wheel adjuster frozen in reply to Mike M, 05-01-2006 09:44:24
Yeah I took the jack screw from the other side so I had 2 on the side I needed to move, but couldn't get them flush with the hub. Do you just drive the wedge out with a punch or does it need to be freed up first?
Mike M
05-01-2006 12:47:58
 Re: 4020 Rear wheel adjuster frozen in reply to MaverickM23, 05-01-2006 12:26:24
Jack up that side of the tractor,put the wedge on the bottom and tighten up the 2 jack screws. Be careful not to strip out the threads and oil everything up good too. Now give the end of that axle a hard whack with that sledge and see if those jack screws loosened up any.Repeat as needed. Once it is loose you may have to use a punch to get it pushed out all the way.
