Hydraulic Valves
Dan
11-28-1999 09:12:07
I have a JD2010 with what i believe is a aftermarket hydraulic valve for the loader the name on it is HCI-PRINCE which i'm wondering if anybody knows if you can get parts for these or if i need to buy a new dbl spool valve. Retail=$134.99. Any advise welcome!! Thanks,Dan.
Nathan(GA)
11-28-1999 18:38:05
 Re: Hydraulic Valves in reply to Dan, 11-28-1999 09:12:07
Dan, I might be wrong, but seems like I have seen the Prince valves in Northern Hydraulic Catalog. I think they changed name to Northern Tool now though. I haven't seen a catalog in a couple of years. Another option would be a machine shop turn a new spool with your broke one to go by.
Good Luck, Nathan
Dan1
11-28-1999 19:39:16
 Re: Re: Hydraulic Valves in reply to Nathan(GA), 11-28-1999 18:38:05
Thanks again nathan i found northerns site online at northerntool.com and they do have prince valves! later, Dan
Nathan(GA)
11-29-1999 13:19:55
 Re: Re: Re: Hydraulic Valves in reply to Dan1, 11-28-1999 19:39:16
Glad I could help. Makes me feel good that my memory is not as bad as I thought.
Nathan
Dan1
11-29-1999 16:09:22
 Re: Re: Re: Re: Hydraulic Valves in reply to Nathan(GA), 11-29-1999 13:19:55
I heard all that if its not written down and in front of me its history!!!
Dan1
11-28-1999 18:50:23
Thanks we've got a Northern store in town but i didnt see one there i'll check the catalog just to make sure thanks!!!!!
mark
11-28-1999 14:25:21
about the only thing that goes bad in A SPOOL VALVE WOULD BE THE O-RINGS THAT ARE USED FOR SEALS. ANY COMPETENT HYDRAULIC SHOP OR PARTS HOUSE SHPULD BE ABLE TO FIND O-RINGS OR SEALS TO FIT UNLESS YOU ARE HAVING MAJOR TROUBLE WITH YOUR PRESENT VALVE I'D SAVE MY 135.00 DOLLARS
Dan1
11-28-1999 17:08:36
 Re: Re: Hydraulic Valves in reply to mark, 11-28-1999 14:25:21
Well you see thats the problem the spool is in two pieces. So I need some kind of diagram or to contact the company for replacement parts. Thanks for trying though. Thanks Dan1
