JD 320
Mark Watkins Ky
04-29-2006 17:09:09
A friend of mine has a JD 320 tractor. He was taking off the exaust manifold and broke 3 of the manifold bolts in the head. In using an easy out on one of the bolts he broke it off also. Does anybody have a suggestion that might help get the easy out/bolts out?
machinery-man
04-29-2006 18:18:39
 Re: JD 320 in reply to Mark Watkins Ky., 04-29-2006 17:09:09
If the break is at the surface, I would clean up the head and take a clean nut and weld it onto stud. Then I would allow to cool and use a small breaker and work lightly back and forth, you might be lucky. The weld will allow some expanding of the stud threads then cooling may allow enough movement that they will come on out. Get a good weld head to nut. A mig welder works good with this.
