No spark
Abbot
04-29-2006 17:02:26
I have a 1969 or 1970 110 lawn tractor and it just quite. Found out there is intermittent spark to mostly no spark at all. Tried a different spark plug no good. Also checked it right to the frame nothing. Need to know what to do next. Thanks.
farmer n bibs
04-30-2006 08:35:15
 Re: No spark in reply to Abbot, 04-29-2006 17:02:26
You need to see if your coil is geting power.
If it is then see if th pickup is working properly.Go to the negitave side of the coil with a test light and crank th motorthe light should flash.If it doesnt you need to replace you pickup.
good luck.
Abbot
04-30-2006 06:43:40
Did all of that also. Thanks
Maark
04-29-2006 19:03:34
Replace your points and condenser. set the points at .020
